About to pull the outer primary on a '14 SG. 19500 miles
Have a little chatter that I want to investigate.
Is the gasket reusable?? I want to have a new on on hand if it's not..
Suggest you look at the shiny spots of the compensator cam. Mine began to make some noise and I found the shiny wear marks about an inch long on each side of the valley. I added an old medium sized spring as a shim and it is quiet and smooth now. Harley got tired of replacing compensators because of noise and made a shim pack kit that can add preload to the springs, that is probably all you need to quiet things down.
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
As mentioned, Harley came out with a procedure to measure and then add shims to a '14+ noisy compensator, that will quiet it down....
