107 Big bore kit
Old Oct 30, 2019 | 12:20 AM
Banks's Avatar
Banks
Stage IV
Default 107 Big bore kit
Hey does anyone have the fuel moto big bore kit on their ultra classic? I was wondring how well the bike performs and if anything with the drivetrain needs to be changed?
Old Oct 30, 2019 | 04:41 AM
sanman4ever's Avatar
sanman4ever
Old Oct 30, 2019 | 06:57 AM
hattitude's Avatar
hattitude
Well, you asked....
https://www.hdforums.com/forum/touri...fuel-moto.html
To specifically answer your question, I have not read of people going with the 107 that needed to upgrade their drivetrains due to clutch slippage.... although I would always go to a heavier spring even with my Stage I upgrades......
You could always do the big bore, and then based on how your bike responds to the new power and your riding style, go through the clutch improvement progression.... stronger clutch spring, then variable pressure clutch, and eventually a new high performance clutch set-up...
Good luck with your mods...
Old Oct 30, 2019 | 07:03 AM
Beaux's Avatar
Beaux
https://www.fuelmotousa.com/series-2...re-clutch.html
Old Oct 30, 2019 | 04:31 PM
bmaier's Avatar
bmaier
I did the Fuel Moto 107 EZ with TW555 cams on my 09 Ultra and added a AIM VPC 95 to the clutch as a preventative measure while doing the build, I like the light pull with the stock spring so didn't change it, still running the stock clutch cable at 132,000 miles. The VPC 95 is supposed to be able to handle 140ft lbs + with stock spring.
Old Oct 31, 2019 | 12:03 AM
Banks's Avatar
Banks
Stage IV
Thanks for the info everyone, looks like I got some homework to do.
Old Oct 31, 2019 | 03:03 AM
1 2 many's Avatar
1 2 many
Buy once cry once go S&S T124
Old Nov 2, 2019 | 09:02 AM
pounder35's Avatar
pounder35
what he said . after you get tired of 107 then what? Just go do a 124 and get it over with
Old Nov 2, 2019 | 09:18 AM
grbrown's Avatar
grbrown
Wink
What do FM themselves recommend? They seem to provide a very complete package for each of their upgrades, so it's difficult to imagine they over-look the clutch - if it needs attention! I have a 107", although not one of theirs, and installed a stronger clutch spring. I also changed the comp and primary chain as they were both showing signs of wear, although that will depend on mileage and usage of your own bike.
Old Nov 2, 2019 | 10:20 AM
Uncle Larry's Avatar
Uncle Larry
Or a Jims 131, 135 or an S&S 143 ... there will ALWAYS be something bigger and or better :>)
