anyone heard anything about the rear pipe mount at the head cracking due to the rigid mount pipe and rubber mounted motor???? just ordered a set and was told this
A couple of years ago or so, Rinehart redesigned the bracket for the rear cylinder due to some brackets breaking. The redesigned bracket has apparently solved the problem. When I bought mine at the time, BUB supplied the redesigned bracket. Buying a set now you shouldn't have the issue.
I replaced the bracket a few months ago. Had the exhaust since 2003 with no problem but changed the bracket to be on the safe side. The new bracket is a lot thicker. Even though the old bracket was in good shape the weld for the bracket seemed to be coming apart.
