Road Glide Starting issue
Prior to hitting the start button, the engine has no internal pressure and is relatively easy to turn initially. As the engine rotates, compression builds and it gets increasingly hard to rotate the crank shaft.. With a FIRM compensator, MOST of the starter energy is transferred into the crank shaft BEFORE compression begins to build giving the flywheel and rotor some inertia to help the starter through the first compression stroke. With a SOFT compensator, most of the starter energy is absorbed by the compensator but even so, the crankshaft begins to turn SLOWLY but develops little inertia as compression builds. As compression builds, the compensator finally runs out of movement BUT there is still little inertia already on the flywheel and rotor and the starter now has "NO HELP" in pushing through the rest of the compression stroke and slows or stops until some compression dissipates. Based on this THEORY, my recommendation would be to install some spring shims to increase spring preload. The only ones I know about are part number 10300021. They are not very thick and at least 2 or 3 might be needed, they sell for around $5 each and may need to be ordered, I doubt they are kept in stock. Again, due to the late season when I installed mine, the experience after install is very limited, AND again, for this advice, you get what you pay for.
As others have indicated, a new battery will most likely be the "quick" fix, but the problem will return and make you want to again replace the battery when it really hasn't reached the end of its service life yet.
I'd get jump pack, unless its normal for you go through batteries this quick.
Since you removed it, it should be tight. That may be the biggest problem.
If it does it cold, I would put a battery charger on it at starter up, on 10 amp. And see if it makes a difference.
Are you letting fuel pump pressurize before starting?
If it load tested ok, I would not buy another battery. Though I don't load test to know how accurate they are. I just kinda wonder if you are worrying. But I am not goign to be the one stranded.
