flipped tail light
Old Nov 15, 2019 | 11:43 AM
sidewalkman's Avatar
sidewalkman
Default flipped tail light
Hi Gang, I'm looking to put the license plate below the tail light, have been looking around but can't find a tail light that would work.
Ideas appreciated, also if it comes with the license bracket even better.
Old Nov 15, 2019 | 11:55 AM
cprhed's Avatar
cprhed
There is a bracket available that allows you to move it under the stock tail light. Then you could change out the lens to get rid of the white light window on the top. Most states require a lighted plate, I was considering lighted bolts for the license plate. All available from places like JP cycle
Old Nov 15, 2019 | 11:56 AM
89FLHT's Avatar
89FLHT
+ 1 for JP Cycle - they have the relocation bracket and the tail light lens needed.
Old Nov 15, 2019 | 01:24 PM
btsom's Avatar
btsom
The recent production machines have a tail light/license plate mount bar with an integral light just above the plate. A different tail light lens and simple plate mount may be the least expensive way to go, but you might want to see if a lighted tail light/plate mount bar is too expensive. I would like to move my plate to below the tail light also, but it isn't worth much trouble or expense to me. Have you or a passenger nicked an ankle on the license plate when swinging a leg over the bike? Can't believe Harley ever thought the plate ABOVE the tail light was a good idea.
Old Nov 15, 2019 | 03:16 PM
slvdout's Avatar
slvdout
By looking at your sig i assume that its the '07 you want to make this change on. I have an '07 Roadking and i have relocated the plate, I purchased the entire taillight and turn signal assembly for an '09 Street Glide. it bolts right on. looks way better IMO.
Attachment 617377
Old Nov 15, 2019 | 03:37 PM
sidewalkman
Mine has the tourpak on it so nicking an ankle on the license plate isn't an issue,
Lone Dawg
Apr 15, 2013 06:42 AM
customsoftail200
Touring Parts
Feb 29, 2012 06:08 PM
skydrifter
Dec 21, 2009 08:05 PM
homerandpooh
Nov 11, 2009 04:13 PM
texasridr
Jul 3, 2008 10:00 AM
