2006 FLHTCUI ultra classic- Unusual Speedometer Problem
Old Dec 25, 2019 | 12:24 PM
NeurOn's Avatar
NeurOn
Stage IV
Default 2006 FLHTCUI ultra classic- Unusual Speedometer Problem
Hello to all.. I am new here and also new owner of 2006 Electra glide Ultra Classic. I have very unusual speedometer problem.
Speed is going to full speed(120ml/h) already when i go slow.. and also odo is because of this going fast up.
I did not run yet diagnostic procedure, but i changed the speedo sensor with the new one. I also tried to change with new original speedometer, but
the result is just the same.
Any ideas? Please help me if you already had problem like this.
i chacked the grounds behind the battery and are ok
voltage regulator is working ok
-check engine light is comming and going on!
Thanks.
Old Dec 26, 2019 | 08:57 AM
Crotonrz's Avatar
Crotonrz
You really need to go through diagnostics for that problem, although if you've tried replacing both the speed sensor and speedo itself, they only thing left in the speedometer 'circuit' is the ECM. Speed sensor data is sent to the ECM which in turns sends it out on the Serial Data line which goes to the speedo, tach, data link, radio, possibly more, can't think off the top of my head. I would check for a wire rub in the front fairing, there is a large loom section that sits above the radio, feeds the speedo, tach etc, they are quite infamous for rubbing against the edge of the inner fairing main support, in particular the right hand side (if you were sitting on bike). Other than that, you'd have to work through diagnostics.
Old Dec 26, 2019 | 12:09 PM
NeurOn's Avatar
NeurOn
Stage IV
i checked the codes and they are like this:
- P No Rsp( no response)
- B1121 left turn out fault
-U1255 missing response at tssm/missing response at speedometer( have to check if all conections are ok)
-U1097 loss of speedometer serial data at tssm
i will check what i can find out if i check the wires and the tssm module.
any ideas if tssm module can be damaged?
Thanks.
Old Jan 2, 2020 | 11:07 AM
NeurOn's Avatar
NeurOn
Stage IV
ok..update...i cleared all the codes and only one in P = P1651 cant be cleared. if i try to clear the code i got the massage No rSP.
engine light is 4s off and 8s On and repeats. Still my speedo is going to 120mi/h even if i drive slow...
Again..any ideas?
Hdriderindallas
Aug 6, 2017 09:21 AM
newlands97
Exhaust System Topics
Mar 3, 2013 05:55 PM
FirstHarley
Motorcycles For Sale
20
Oct 5, 2009 05:46 PM
rriley
Aug 16, 2009 12:09 PM
macdaddy55
May 4, 2007 02:03 PM
