Keys
Old Jan 27, 2020 | 08:57 AM
Jackie Paper's Avatar
Jackie Paper
Take it apart and match the pins to work. You only need a couple, so if need be, file the longest ones.
Old Jan 27, 2020 | 10:41 AM
havinabubble's Avatar
havinabubble
Originally Posted by wolfvon
Got a new saddlebag with lock and keys. But, the keys don't work on cover for gas, ignition, other saddlebag and vice versa. How do I get keys with same number as for the other things on my bike? I guess what I need is a new lock on the new saddlebag that fits my original bike key-number.
can only speak for the gas door, but I'm led to believe all our keys can open them!
The ignition (and the bags) are coded. Goto a dealer with your VIN and they can pull up the code on screen.... then they can order coded locks
Did it 2 weeks ago.
Walked into my local dealer to get a gas door lock as mine was playing up... they happened to have one in stock. When I questioned 'so hows that gonna work with MY key?' it seemed the lock had a specific 4digit code on the end, which was different to mine.
Tried to order THAT part but with my key code and the system wouldn't allow it to be entered. Called another member of staff.
After much discussion we put my key straight into the unwanted lock they had in stock and it turned fine! pulling the black pin back as it should
She then recalled that gas doors where all the same in her experience, but ignitions (and bags) require an appropriate code (hence why the system allows them to be ordered with the appropriate key code)
YMMV
Old Jan 27, 2020 | 11:03 AM
jimglassford's Avatar
jimglassford
Not all locks can be ordered as a service part.
Old Jan 28, 2020 | 02:02 AM
svarnster's Avatar
svarnster
can u pull the lock out of the original bag lid and swap it over.
Old Feb 3, 2020 | 06:55 AM
Campy Roadie's Avatar
Campy Roadie
Will locks from pre-toilet handle bags fit in the new toilet handle bags?
Shem77
EVO
May 30, 2019 09:02 PM
bspencer
Aug 13, 2013 11:34 AM
hevis1
May 26, 2013 08:54 AM
swaite
Sep 23, 2009 12:21 PM
pachowder
May 2, 2009 12:00 PM
