Winter Project #2!
Old Jan 31, 2020 | 12:08 AM
Superdog3:16's Avatar
Superdog3:16
Default Winter Project #2!
Hi guys, me again. Project #1 finished, now for the second I wanted to do this winter. I really should wait a month or so to spread these out, but I can ask for opinions and suggestions NOW. After this, the bike is DONE.
2014 RK stage 1. I wanna put dual header on. Considered just de-catting, but I think the dual header looks nicer. What you guys running. I already have Cobra NH muffler's on it from my Stage1 upgrade, they will be used on the new header. Thanx in advance.
Old Jan 31, 2020 | 07:58 AM
decencyxdefied's Avatar
decencyxdefied
I have a set of cobras on mine
Old Feb 1, 2020 | 01:51 PM
tn_popo's Avatar
tn_popo
I'm planning on going with Vance and Hines Power Duals with V and H Monster Rounds.
Old Feb 1, 2020 | 02:56 PM
Superdog3:16
Looks pretty straight forward, easy job. Just don't gorilla the header flange bolts.
Old Feb 1, 2020 | 05:12 PM
MyFavRk's Avatar
MyFavRk
Running the V&H True Duels / Duals <- on mine ( Cross Thread Points ) , love the the sound , and I don't see much loss in power . Make sure you use the proper exhaust gaskets , and make sure you tighten to the correct torque spec and then re tighten after they cool off . Make sure you check your manual for the correct torque secs , I believe you tighten the top nut using only half the torque spec , then tighten the bottom nut to the full torque spec , then finish the top to the correct torque ... someone will correct me if I'm wrong .
Man , I love working on bikes , enjoy !
Old Feb 1, 2020 | 06:10 PM
Superdog3:16
What muffler's you running? Did you have those b4 you did the headpipes?
Old Feb 1, 2020 | 06:41 PM
MyFavRk's Avatar
MyFavRk
When I first got my King , I decatted the stock header and ran the oem slip ons , not loud enough , but ran much cooler . Later on , I picked up a set of SE Street Cannons and modified a set of Crusher Mellow Baffles to fit and then added the True Duels , perfect ... nice deep rumble and has a pretty good roar when you get on it . The NH slip ons are a good choice , probably what I would have gone with if I hadn't have succeeded with the SE mod .
hdnvn
Apr 13, 2014 07:40 PM
kyote
Feb 11, 2010 11:26 AM
BarneyMN
Shovelhead
Apr 16, 2008 08:20 PM
CGLTD
Oct 21, 2007 07:39 PM
rob_will
May 31, 2007 09:32 PM
