Very Rough Idle When Cold
Old Feb 26, 2019 | 02:21 PM
Throttle1971's Avatar
Throttle1971
Default Very Rough Idle When Cold
2007 Street Glide with 110
Only when the engine is cold, when I first start it up it sounds like the engine is galluping, idles very rough. Hard to explain, but after 2-3 minutes when the engine warms up the idle and engine will smooth out and all is fine. This problem has been going on for a few season. Reminder this only happens when the engine is cold both in the summer and winter, abviously a little worse in the winter! This has been happening for 60K miles or so. Thought I would try to get it fixed finally. Just incase this might answer a few of your questions as you are thinking about my issue, I have done the following over the past few seasons.
  • Voltage Regulator
  • Stator
  • Starter
  • New Battery
  • Traded in old thundermax ECM for new one.
  • Spark Plugs
I was thinking possibly it might be the engine temperature sensor.
Thoughts?
Old Feb 26, 2019 | 02:51 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
A few useful tricks to zero in on things when it's cold and running rough.
Timing light in the spark plug. Does it flash? Obviously this is easier with two timing lights, one on each plug line. If one doesn't work, it's ignition and on that circuit.
Disconnect one fuel injector, then the other. If one doesn't make any difference, be suspicious of that injector/wiring. A noid light on the injector plug will tell you of the injector is getting a signal or not. If it is getting the signal, but not responding when cold, it's the injector. If the signal is missing when cold, you've more diagnostic work to do further upstream.
This may take you a few tries as inviariably the engine will warm up and start running right.
Old Feb 26, 2019 | 10:41 PM
RevBlk's Avatar
RevBlk
I would bet serious money on IAC. Common issue on 07's. Just changed mine.
Old Feb 27, 2019 | 07:53 AM
vanman59's Avatar
vanman59
just a guess but is the engine temp sensor output correct? with power vision i can monitor my temp. Don't know if the ECM looks at eng temp to determine if it should be in closed or open loop. If the ECM thinks the engine is at temp it might not be putting enough fuel when cold.
Old Feb 27, 2019 | 07:57 AM
MURPHCC1's Avatar
MURPHCC1
Clean IAC......inside throtle body at the 12 oclock position.......stuff shop towel in throttle body........turn on ignition but dont start..........rock kill switch back and forth while using that straw on (I use brake cleaner) cleaner and spray...moving it around inside orifice.......will probably be pretty dirty.......
Old Feb 27, 2019 | 08:21 PM
btsom's Avatar
btsom
"Galloping" and "rough" imply different things to me. By galloping, do you you mean the rpm cycles from low to high and back down again? For that, the IAC guess is a good one. By "rough" do you mean the the engine is shaking much more than normal but the rpm as fairly constant? When you changed plugs, how did they look? Was one significantly different from the other? One being extremely clean may suggest an intake air leak that causes misfire when cold. You made an excellent try to include all of the vital information, but plug condition might answer the question. And clarifying "gallop" and "rough" would help also.
Old Feb 27, 2019 | 08:31 PM
Throttle1971
Both plugs looked identical when I pulled and changed them. Your second on how the engine runs is correct. The RPM stays steady, doesn't flucuate at all.
Old Feb 27, 2019 | 08:56 PM
btsom's Avatar
btsom
Does the cold idle rpm seem lower than normal warm idle or a faster, more normal warm up idle rpm but just very rough? Have you checked for any stored codes?
Old Feb 28, 2019 | 05:47 PM
Throttle1971
No stored codes. The cold idles is higher than normal idles around 1400 rpms. I will try to do a video this weekend and see if that helps.
Old Mar 6, 2019 | 02:55 PM
Throttle1971
I did a data dump from my Thundermax ECU and upon the technician reviewing the results, this is what I was told.
"QUOTE FROM THUNDERMAX"
There is an issue with the IAC motor and TPS setting. The TPS should set at a value around 10-12 degrees if you link and pick monitor and look at the Throttle Position gage. The TAC value should show 85. Once the bike starts the TAC value should go down and yours goes up way up to around 120 steps. Like it is lost then after a couple of minutes it starts going down and the bike starts to come around and idle well. This is not something that can be adjusted at the ECU level but I believe should be adjusted at the throttlebody.
Any ideas here on what I should do next?
