It battery time
Old Feb 17, 2020 | 06:40 AM
lucarmand's Avatar
lucarmand
Of course, my application was a simple carb bike, so not the power requirements of EFI, security, et c. I do think the AGM technology is a vast improvement over the conventional lead/acid. I have not used a Li battery myself b/c of the upfront expense, and I think you need a Li-specific charger. I am interested what others who have them say about performance and longevity of those batteries in a moto.
Old Feb 17, 2020 | 08:27 AM
04FordHarleyF250's Avatar
04FordHarleyF250
I like using the Duracell brand from Batteries Plus. When traveling, there is usually a Batteries Plus store anywhere you go and they will do a warranty replacement if ever needed. (I haven't had a battery die on me on the road yet knock on wood). Buy it online and go to the store to pick up and it's cheaper than going to the store directly. They take the old one as well. I saw the new lithium battery at the dealership. It is very light in weight and powerful. The problem with Lithium batteries is they give out with no warning. They last twice as long if not longer but I don't like surprises especially when traveling.
Old Feb 17, 2020 | 08:58 AM
Hecklerboy's Avatar
Hecklerboy
My original battery lasted 7 years in my SG.
Replaced it with a OEM Harley battery and after 2 years it's still going strong.
Old Feb 17, 2020 | 09:11 AM
Uncle Larry's Avatar
Uncle Larry
Replaced the original battery in my 2009 FLHTCU after 7 years for peace of mind ... Used a Big Crank from Battery Mart ... No core .. $100.00 delivered ... So far so good !
Old Feb 20, 2020 | 12:28 PM
halnwheels's Avatar
halnwheels
Default It's about the form factor, too
There are good battery companies out there like Yuasa, but I have trouble with them because their terminals require these little adapter blocks, and you can't mount connections on top and the sides at the same time. The adapter blocks are just another place for connection resistance and they loosen easily. For this reason, I stay with the Harley battery. It's a decent battery and it connects up better than the others.
Old Feb 20, 2020 | 01:34 PM
Holzarbeiter's Avatar
Holzarbeiter
Originally Posted by nutsandbolts5212
batterymart.com, big crank delivered to your door, $100. Only batteries i buy for my bikes.
Ride safe!
^^^same^^^
Old Feb 20, 2020 | 01:51 PM
Steve Helton 2's Avatar
Steve Helton 2
https://www.throttlexbatteries.com/s...xfDLV-9RsYPvPU
I have one of these the 600cca
Old Feb 20, 2020 | 07:09 PM
eaglefan1's Avatar
eaglefan1
Originally Posted by Steve Helton 2
I have the same one. Spins it over real good. I have manual compression release also but there was a difference from the stock battery for sure
Old Feb 29, 2020 | 07:07 PM
zoozoo's Avatar
zoozoo
I have never gotten a Harley Battery to give me more than 3 years of service and that's using a battery tender every time it's parked in the carport. As a matter of fact, my wife's battery went out on her today luckily we had stopped to eat and there were people there who gave her a jump. The battery, Harley, is only two and a half years old. I'm ordering her a Big Crank from BatteryMart and while I'm at it I'm ordering one for my Limited. Today's batteries just don't last like they use to.
Old Mar 14, 2020 | 07:27 PM
stuckinnj's Avatar
stuckinnj
Curious if there is a learning procedure required when replacing battery on 16 Road Glide. Most new cars require a ‘learn’ procedure due to the charging system requirements. Yeah,if U own a newer car, domestic or import, you can’t just change out a bad battery anymore. The charging system needs to recalibrate. So back to the H-D, anyone confirm or deny if a learning procedure is required? Changed out mine and find the volt gauge fluctuating between 14 & 14.5v while cruising. At idle, it remains steady at 14v.
Thoughts are welcome.
