Wheels
Old Feb 18, 2020 | 07:17 AM
Tjayrossignol's Avatar
Tjayrossignol
Stage II
Default Wheels
Does anyone know if wheels off a 2012 road glide will fit on a 2003 electra glide? Both have one inch axle. All I think I have to do is change out bearings for non abs bearings.
Old Feb 18, 2020 | 07:47 AM
eighteight's Avatar
eighteight
You have 1" axle
I believe `08 and up are 25mm
Both sizes have the same O.D. but there is a difference in width and IIRC this requires attention to spacers
Sure someone here has more details or you can find a past thread
Old Feb 18, 2020 | 07:52 AM
Tarkus60's Avatar
Tarkus60
The rear will not fit...180 verses 130. 2009 frame change.
Old Feb 18, 2020 | 11:37 AM
eighteight's Avatar
eighteight
Go to wheel & tire section , see thread entitled " 21 on a slim" for particulars
No you can not use a 180mm rear TIRE, but assuming the new WHEEL is 3.5" or 4.0" wide you can use a 140 or 150
Old Feb 18, 2020 | 02:24 PM
caulk04's Avatar
caulk04
Rear wheel is a no-go. Not happening.
Front wheel can be done, just get the correct bearings for YOUR BIKE and put them in the new wheel. Keep the inner spacer that's with the wheel, use your outer spacers from the bike.
Old Feb 19, 2020 | 03:06 PM
multihdrdr's Avatar
multihdrdr
That won't work ... Not the way described
Old Feb 19, 2020 | 07:56 PM
caulk04's Avatar
caulk04
I suppose, on second thought, there is more to it. Not sure what I was mixing up in my head.
I don't have the correct recipe in my head, but I do know that the front can be done and the rear cannot.
Hogleyripper
May 13, 2022 05:45 AM
Partsman116
Wheels/Tires
Feb 18, 2018 06:50 AM
Michael Dahl
Jan 30, 2018 02:59 PM
sgillikin
Wheels/Tires
Mar 22, 2016 10:41 AM
bdbaggr
Nov 10, 2010 02:19 AM
