Rear Brake Line Leak?
Old Feb 19, 2020 | 10:02 AM
rozemab's Avatar
rozemab
Default Rear Brake Line Leak?
FLHRC 2009
Has anyone seen a leak at this junction on the rear brake line? Some brake fluid drops were found underneath this junction. Tried to duplicate it manually (pressing on the petal) but could not get it to leak again.
Maybe another source for the leak?
Leaking from this point, but I could not get it to 'leak on demand' manually. Is this just a simple crimp etc ?
Old Feb 19, 2020 | 10:16 AM
Jackie Paper's Avatar
Jackie Paper
Need a camera shot..
Old Feb 19, 2020 | 07:41 PM
J2X's Avatar
J2X
is it the hydraulic brake switch?
Old Feb 19, 2020 | 08:43 PM
jimsuver's Avatar
jimsuver
It sure was on mine
Old Feb 19, 2020 | 09:18 PM
totalgearhead's Avatar
totalgearhead
my '08 FLHX rubbed right through at that point and rear brakes failed. I joined together with a compression union fitting, as i was on a trip and still a day from home. I had to replace the line when i got home, as it has the rear brake light switch fitting integrated with it.
Old Feb 20, 2020 | 07:52 AM
Lude-a-tick's Avatar
Lude-a-tick
Also check for clutch cable routing. Had a RK in the shop, clutch cable wore a hole in the brake line over time.
Old Feb 20, 2020 | 08:18 AM
rozemab's Avatar
rozemab
Tried again to get it to leak. I exercised the pedal, held it down, and placed a plastic bad underneath to catch any drops (overnight).... nothing yet.
I'm starting to think I dreamed the leak but I remember smelling the drops and it was definitely Dot4 fluid, not water.
The scary thing, it's the rear brake line, don't want to find out it fails at 70 mph.
I'll keep looking and try to get it to leak. Peace of mind I may change it out. $100
I will check for rubbing and other unusual wear.
moneypit1
Sep 20, 2019 02:44 PM
matte
2014-2024 Touring Models
Jul 17, 2017 08:15 AM
Mad Viking
Jul 27, 2010 02:55 PM
Black Bart
Wheels/Tires
Jul 21, 2009 02:10 PM
Rich G.
Ironhead
Nov 3, 2008 08:48 PM
