brake fluid leak?
Old Sep 18, 2019 | 07:53 AM
moneypit1's Avatar
moneypit1
Default brake fluid leak?
I went to get on my ultra (2012) yesterday and noticed a little brake fluid from the rear caliper cleaned everything up and checked level it was still ok ? went for short ride and everything seemed ok? what would cause this?
Old Sep 18, 2019 | 08:19 AM
GalvTexGuy's Avatar
GalvTexGuy
Photos would help. Did you happen to notice the exact spot on the caliper where you saw the fluid? You don't think your air shock might be leaking, do you?
Old Sep 18, 2019 | 08:30 AM
Jackie Paper's Avatar
Jackie Paper
It wasn't brake fluid. But just in case, jack it up. Inspect the line from rear master to the caliper. Then have someone load up foot pedal and hold it down. Make sure it is not dropping and you see no leaks. This problem, if it is real, can get you worst then dead
Old Sep 18, 2019 | 09:08 AM
moneypit1's Avatar
moneypit1
is there oil in the air line for the shock? that could be a possibility? I will do what you said on loading up the brake tonite after work... thanks
Old Sep 19, 2019 | 10:06 AM
moneypit1's Avatar
moneypit1
ok so good news and bad news ...the good its not the brakes....the bad it s the air shock..shocks...now what? anyway to fix or just get new shocks?
Old Sep 19, 2019 | 04:07 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Ditch the crappy air shocks and upgrade into something that will actually work
Old Sep 19, 2019 | 04:19 PM
95hdtlk's Avatar
95hdtlk
Same thing happened on my 15 Limited last year with under 30,000 miles . Left rear shock just all of a sudden , started leaking fluid . Not having $ 700-1,000 for good quality rear shocks , or $ 200 . for one new dealer shock , I found a used pair at Azcycleparts.com for $ 59.99 delivered to my front door . Replaced the bad one and have a spare .
Old Sep 20, 2019 | 02:44 PM
moneypit1's Avatar
moneypit1
thats what im thinking ditch them ...are my stock ones on a 2012 ultra 12" or 13" ?
jt metal
Aug 8, 2019 08:57 PM
Ausreed93
Mar 22, 2018 05:04 AM
Bogart999
Mar 20, 2014 04:19 PM
Matt K
Nov 20, 2013 06:26 AM
max56
Jul 29, 2008 10:26 PM
