Concerned about owning a Harley
[color=#222222
One thing a lot of people fail to realize is that forums like this one are made up of enthusiasts so it's only natural that there would be a lot of posts about mechanical issues. The same holds true for any enthusiast forum. Log onto a forum about Honda automobiles and you'll see a lot of posts about broken down Hondas.
So with all that and my tools and twist ties I will ride on. I just need to get the first 300 miles in before my warranty takes effect. Cross my fingers.
To all that responded to my post with good advice and intentions. Thank you.
To all other smart assess. Who cares!
Well, I can clearly see that you will fit in here just fine. You can take well intended jab and keep rolling on. That fix right away is certainly a kick in the ***** and would have pissed off even the most seasoned of us. But, now you will have that fixed and no longer a worry, and you have this thread to prove you survived the FNG hazing process.
Now on to the real stuff. The warning that every HD should come with before you sign.
WARNING:
You are about to purchase a Harley Davidson. Once signed this purchase agreement absolves the seller from any and all responsibility for your future addiction problems. It is highly recommended for your own mental well being and for the sake of your checkbook that you not participate in any harley related forums, websites, webchats, nor should you attend any motorcycle related events or look at pictures of other peoples' Harleys. Failure to adhere to these warnings will result in a deep and incurable addiction to tinkering, modifying, customizing, and updating your motorcycle for no other reason that you "had an itch".
You have been warned. Those "break in miles" are like taking your first hit. Then you're hooked. Welcome to the addiction. Weekly rehab here, bring donuts.
Oh, and my previous bike was a Vulcan Nomad. Loved it. Most comfortable stock seat I have ever had. But it was way under powered for the size it was. I'll never go back.
It If I had not owned a Harley when I started reading these forums I would have NEVER bought one. ..especially a used one. Over the recent year or two, this Forum has turned into one of the most negative forums I have seen. Some people just can't wait to post about a problem they've had.
I don't know if I'll ever buy another used Harley or not...probably not. Mainly because of what you said Lattitude. It's amazing what you see here about folks that work on their own bikes and what they have done to them. ...folks that don't have a clue what they are doing. Also folks that "short-cut" things they do. And these folks are giving bad advise to others too. It's really scary.
If I was going to buy a used bike, I'd want to see a service history DOCUMENTED, by a QUALIFIED service professional, not some DIY jackleg. You can open up my right saddlebag and pull out gallon size Zip Lock bag with my owners manual in it, with ALL the receipts of the service work done on my bike...by my Harley Davidson Dealer. And it's all been done at the proper service intervals too, mileage wise. If a seller can't provide that kind of info to me, I don't buy that bike. That's my version of a CARMAX history.
And for the record, I have NEVER owned a Harley that didn't have an issue at some time. When I read these quotes from folks that say they haven't had an issue with their Harleys and they have ridden many thousands of miles on multiple Harleys over a long span of years, I just shake my head. I must be the most unlucky Harley owner ever, or some of these folks have a bad problem with memory. Really, no problems at all? And all you did was change tires and fluids? REALLY???????????????? Boy, I wish I could make a statement like that.
Of course they have had issues. However, here's the caveat: what WASN'T an issue to them, might be a "broke down on the side of the road stranded" issue for others. For instance, a shifter linkage break. A shifter shaft strip and they are stranded too, because you don't pull the whole primary and tranny apart to repair that shaft that won't work to change gears when you're on the side of the road. Thank goodness the Cam Tensioner issue has finally been fixed by Harley.
As far as DIY hacks go I am one. I have all my records in OneNote however. I do my own maintenance and upgrades. I am not a trained service tech but I am a degreed Mechanical Engineer with a Masters degree and work in the Powertrain and Electrical business of the Auto Industry and have WRITTEN maintenance procedures and trained techs. If I screw something up I will figure out how to fix it...I would never just sell my boat, motorcycle, or car to push the issue to someone else.
Now I've had great luck with my Ultra Classic but this is why I waited so long to move from Suzuki.
