Switched power source...
Old Feb 20, 2020 | 09:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Default Switched power source...
On both of my 02 and 05 Dyna's I used the BE (blue) wire to the rear running taillight for switched power. I want to splice into the rear running light on my 2013 Road Glide Ultra, is the BE (blue) still a viable switched power wire?
Old Feb 21, 2020 | 05:22 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Look for an orange wire with a white stripe for switched power. I have used this wire on my 2011 RK and my brothers 2013 RK.
Old Feb 21, 2020 | 07:36 AM
RKZen's Avatar
RKZen
I'm not sure about the BE wire, but you could also try the accessory plug under your seat. The green requires the ignition to be on or in ACC. The orange is switched to both the ignition and accessory switch.
Old Feb 21, 2020 | 10:49 AM
14GuineaPig's Avatar
14GuineaPig
The BE (Blue) wire would be power for the running/tail light on the 2013 Road Glide Ultra
Old Feb 21, 2020 | 09:02 PM
seniorsuperglideE8
Thanks 14GuineaPig, I knew I could use the Deutsch plug under the seat but I'd rather save that plug for something that would need to be switched on/off and not require constant power. Thinking about adding a volt monitoring gauge that uses LEDs from red to green for failing voltage levels. I have them on my Dynas and they work like a champ.
Old Feb 22, 2020 | 01:02 PM
RKZen's Avatar
RKZen
I have the Y-splitter on that ACC plug. I have an RK and use a dedicated USB connector for charging my phone or powering a GPS on one and to power my detachable batwing fairing on the other when I use that. Cleaner connections IMO, but splicing and dicing like you're doing results in the same.
DavesEagle
Electrical/Lighting/Alarm
Dec 16, 2018 10:29 AM
star2nv
Audio Systems
17
Mar 30, 2015 06:39 PM
HDMedic340
Shovelhead
Apr 21, 2010 09:20 AM
Curtis629
Oct 10, 2009 06:50 PM
drukanfu
Sep 27, 2008 07:33 PM
