Trunk Lock
Old Jul 20, 2007 | 10:39 AM
WOLFGANG4154's Avatar
WOLFGANG4154
Default Trunk Lock
Trunk lock keysuddenly doesn't work.Can't open the trunk!It inserts but doesn't turn. Can see in through the small slitopening when the latches are released, but can't see anything that helps. Anyone ever dealt with this or have any ideas.
Old Jul 20, 2007 | 10:55 AM
FedRider's Avatar
FedRider
Default RE: Trunk Lock
I had a saddlebag lock do the samething...I used a compressor and cleaned the lock out good with the air. I then used graphite to lube the lock. Works fine now.
Old Jul 20, 2007 | 11:01 AM
GTK's Avatar
GTK
If the lock tumbler in the lock assembly won't turn and you have enough clearance with the latchs undone to raise the lid a little,I would say you'll probably have to drill the center tumbler out of the lock assembly.You will do less damage doing that instead of prying on the tour pack lid.One thing you could do before this is to spray some lubricant into to lock to see if maybe it seized from no lubrication.
Cool Inferno
May 30, 2017 06:13 PM
hevis1
General Topics/Tech Tips
Aug 5, 2013 07:21 AM
128auto
Jun 11, 2011 10:44 AM
Buddha64
Apr 28, 2008 04:38 PM
CSI
Apr 29, 2007 10:47 PM
