I am looking for advice on spring rate selection on the rear of my 2016 streetglide. I currently have pro-action piggy back style 12” shocks with 3” of travel. They have free bleed, slow compression, fast compression, and preload adjustment. I am currently running 128# per inch springs. My problem is I only weigh 130# so I don’t see hardly any change going from free sag to rider sag. The bikes rides decent but little firmer then I would like and if I set sag at 1” I don’t get full travel. I am thinking I should be using a 100#-110# spring.
You want the total sag to be 1" (a 1" compression of the total travel of 3"). That is from the shock fully extended, to total sag with you in riding position on the bike, with your normal load (luggage or whatever). Your preload will adjust this.
I talked to pro-action many times (they are awesome at helping out). The bike rides better then any bike I have owned in the past but with rider sag set at 1" I am only getting about 1.25" of compression. I still have about 3/4" of travel left. George feels I could try a 110# spring but I need to get them custom made. Big $$. I am just trying to gather all the opinions I can before placing order on costly springs.
every spring manufacture told me it would cost an "arm and a leg". The current springs I have are the lightest pro-action had for me. Actually they are lighter then their normal stock springs. I will end up spending the " arm and a leg" but just wanted some input on what others thought. Currently I have about 3/4" free sag and only an additional 1/4 inch from me.
Wear a heavy leather jacket and boots. Carry tools,tire kit and a compressor, that should add a few lbs. Less preload and a bit more compression damping might help.
I spent the evening in the garage and finally had some help to get some measurements to set the sag correctly. Here is what I have.
extended shock length - 12.25"
Free sag - .5"
Rider sag - .75"
Ride height with me on the bike is 11.5"
Preload is 11/16"
Fast compression is set at 0
slow compression is set at 2
free bleed is at 4
Now that I have sag set properly I am getting full travel on bigger hits on the road. Small stuff seems firm but decent. I will still play with the compressions and the free bleed to see if I can get a more plush ride but at least I am headed in the correct direction.
There are other brands available, some of whom will probably supply at normal cost a suitable set of springs. Take a look around, as it may be cheaper to sell your current shocks and buy a different brand, instead of spending a fortune. Depending on what that means, it would be silly to spend a lot of money, presumably to have a set of custom springs made. Make a point of talking to sellers who will ensure they build you shocks to match you. Pro-Action have plainly been very helpful, except at the point of the original sale!
Another thought.... I'm not sure how many miles you have on the P-As, but it's my understanding that you should allow them to have some break-in time before doing too many adjustments,,, and certainly before spending big bucks on custom springs. Like you said, it is already the best ride you've ever had.
