I'm working on a long overdue project (long story...)
and need to verify the width and length of the lower tour pak half as measured across the top opening.
The measurement I have shows a length (outside dimension) of 18 1/8".
I would appreciate if someone could take a moment to check.
Keep in mind that the shape is not asymmetrical as it is longer on the outside edges where the speakers would mount. That said, measuring across the middle from back to front measures 18 1/4 from outside edge to outside edge and measuring across the middle from left to right provided 24 1/4. This was on a 2012.
