6th Gear Tops Out At 3200 RPM
Old Apr 14, 2020 | 09:19 AM
67Shuv's Avatar
67Shuv
I don’t see anything wrong with those numbers.
cold engine during test??
Old Apr 14, 2020 | 09:27 AM
Kokes58's Avatar
Kokes58
No. I warmed it up first. The book said to do the test at operating temperature if possible. I let the bike run for about 5 minutes prior to taking the readings.
Old Apr 14, 2020 | 09:41 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Fuel filter. However, you usually lose your idle if it is the fuel filter on a normal stock Harley since idle is lean. With a tuner and your set up, it would show up at the top end. Do a fuel pressure test. It is always the same so idle or WOT has the same since the relief controls it. Around 65 PSI.
Be sure the throttle body is open when checking compression Throttle by electrical requires you to manually open it or a procedure. This would enable you to not have to take the cover off the filter. However, now would be a good time to do that. Maybe a rodent has taken up residency!? Haa.. Pull the fuel pump relay. You don't add oil unless it is low and then that shows you if it is rings or valves. Leakdown probably is better to check where the leak is if the original standard compression test is low.
Old Apr 14, 2020 | 10:46 AM
caulk04's Avatar
caulk04
Been a minute since I looked at a tune file, but isn't the throttle opening based on gear? Could there be a tuned throttle restriction in 6th?
Old Apr 14, 2020 | 10:56 AM
eighteight's Avatar
eighteight
OP states that bike previously exceeded 3200rpm/ 95mph in 6th.
How fast did it go before this "started" ?
Old Apr 14, 2020 | 04:02 PM
wmprof's Avatar
wmprof
Originally Posted by Camarosx2
1st thing that comes to mind is a partially clogged fuel filter
This. Did you replace the fuel filter yet? Always start with the simple maintenance.
Old Apr 14, 2020 | 06:01 PM
user 47363638's Avatar
user 47363638
Sounds like an electronic problem.
Old Apr 14, 2020 | 06:06 PM
TriGeezer's Avatar
TriGeezer
The higher the gear, and the faster you are going, the more power it would take to go faster. So, I’d look at things that would change and impact power: fuel delivery including pump & filter, dirty or worn injectors, timing, compression although you probably eliminated that.
Old Apr 14, 2020 | 06:14 PM
Hammz's Avatar
Hammz
You won't like this answer, but I saw the same thing on my 2007 UC. Scissored crank. Mine was out on the primary side & the compensator was rubbing against the inner primary. Cost $6k+ to fix.
Old Apr 14, 2020 | 06:18 PM
TriGeezer's Avatar
TriGeezer
Wouldn't that make a gawd awful sound?
