Bike sputtered and died
Old May 11, 2020 | 07:35 PM
twig's Avatar
twig
Default Bike sputtered and died
I’m posting for a friend who has a 2007 CVO Road king on his way to meet me his bike sputtered like it was out of fuel and quit,when I got there he had power to everything except the starter, hit the starter switch and nothing. We pulled every single fuse cleaned the contacts and tried to start after each fuse and nothing, the last thing I did was pull the wire harness to the ECM to get it out of the way then hooked it back up but did not try to start the bike. The tow truck shows up and I decide to try one more time and it starts. We took all the battery cables off and reinstalled them with no luck. Anyone have any similar experience? Thanks.
Old May 12, 2020 | 06:27 AM
hawg50's Avatar
hawg50
check the kill switch.
Old May 12, 2020 | 06:44 AM
Ron750's Avatar
Ron750
Did you only take the battery cables off the battery, or did you check the starter connections too?
Old May 12, 2020 | 06:46 AM
Iceman24's Avatar
Iceman24
Does the bike have any type of piggyback tuner?
Old May 12, 2020 | 01:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I have found on a Sportster and on my Dyna, the cables will over time corrode at the lug ends to a point that only one or two strands of the cable are intact under the insulation at the crimped lug. HD is notorious for having cables just long enough to do the job and that puts stress on the cable ends at the lugs, the integrity is compromised and corrosion sets in.
Old May 12, 2020 | 02:01 PM
Donnylee's Avatar
Donnylee
I have seen a buddys bike do this on a 2007 Ultra. Ended up as a bad ground in the main harness. Hopefully, this is simpler to find!
MTBSully
Sep 20, 2022 06:08 PM
king1pin1
Jul 6, 2019 08:52 PM
ReidRik_Von
Jul 26, 2017 10:58 PM
hd4evr2008
Electrical/Lighting/Alarm
May 25, 2016 04:10 PM
Rocker_C
Aug 8, 2012 12:32 AM
