Turn Signals
Old May 11, 2020 | 07:45 PM
Dusty Kerr's Avatar
Dusty Kerr
3rd Gear
Default Turn Signals
What are the best plug and play Led turn signals, day light running for 2020 SGS?
Old May 11, 2020 | 08:09 PM
Apacheguy1584's Avatar
Apacheguy1584
I have custom dynamics on my 2020 RGS. Bright as **** and only took 10 minutes to change out all 4. Pop cover off, unplug bulb, install new led signal, pop cover back on. Rinse, lather, and repeat 3 more times.
Old May 11, 2020 | 08:33 PM
Dusty Kerr's Avatar
Dusty Kerr
3rd Gear
Do you have to have an equalizer for the rear?
Old May 11, 2020 | 08:37 PM
Apacheguy1584
I do not; per their website the equalizer is only required for 2013 and earlier models. Below is directly from their website.
SMART Signal Stabilizer™ or Load Equalizer required when front or rear turn signals are converted to LED on 2013-Earlier Harley-DavidsonŽ SportsterŽ, 2011-Earlier DynaŽ, 2010-Earlier SoftailŽ, 2013-Earlier Touring and Trikes and all V-RodŽ models to ensure proper turn signal function and flash speed.
Old May 11, 2020 | 08:45 PM
FrankEV's Avatar
FrankEV
Custom Dynamics LED products are about the top of the line for all the turn/brake/run lamps as well as the head light, passing lamps and driving lights. I also have a few Ciro lights...Front fork markers and under extended saddlebag Tail/Brake/Turn lights...that are top quality.
CD has very good customer service also.
Old May 11, 2020 | 08:47 PM
Quik's Avatar
Quik
+1 on the custom dynamics. My 2019 cvo sg came with LED's but I replaced front and rear with custom dynamics pro beams. It's usually the very first thing I do with a new Harley. I have the CD low profile sequential bag lights as well, they are a very nice and very visible addition.
https://youtu.be/k6c079aWZRI
Old May 11, 2020 | 09:32 PM
caulk04's Avatar
caulk04
There are other options out there, but I'll keep going to custom dynamics. Their products are top notch and their customer service is the standard by which other companies should be measured.
Old May 12, 2020 | 05:55 AM
Hawg Runner's Avatar
Hawg Runner
I like Ciro, they come with like a little hood on them, and they are bright.
Old May 12, 2020 | 07:24 AM
user 47363638's Avatar
user 47363638
Custom dynamics, bright as hell.
Old May 12, 2020 | 04:28 PM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
@Dusty Kerr there's lots of options out there, but definitely check out our ProBEAM signals. They've got a lifetime warranty against LED failure, they're DOT and SAE compliant, and they look pretty cool to boot.
https://www.customdynamics.com/amfin...--flhxs--16079
