Rethinking Bottom End
Old May 25, 2020 | 01:29 PM
miner999r's Avatar
miner999r
I had a crank fail on a 2010 FLHTCU with a stage 2 installed by Harley dealer. It failed just over 50,000 Km on the bike. I think the stage 2 was installed previously to 18,000 Km when I bought the bike used from dealer.
There was brass or bronze chunks and flakes in the oil. When shop opened up the engine one of the bronze thrust washers was pretty much eaten up, one con rod had been hitting the fly wheel and the wrist pin bushings were spun. Me I think the crank went out of alignment (scissored??), which caused the rod to contact the flywheel and disintegrate on thrust washer and then maybe the being so far out it caused undue stress on the wrist pins and spun those bushings. I don't know.
The result was a costly engine rebuild from the crankshaft on up.
From my experience, if I would be putting mods for power I would do the crank.
Old May 27, 2020 | 11:54 AM
23Seven's Avatar
23Seven
Maybe I’ll just flip a coin at rebuild time.
Heads Crank
Tails Top End Only
Old May 27, 2020 | 12:57 PM
todd-67's Avatar
todd-67
Originally Posted by 23Seven
It’s fun to ride as is... I’m content for now. Of course I’ll go at least to 107 when the time comes because bigger is always better. I definitely wouldn’t call a 96 a turd once it is woke up with a Cam, Exhaust, and Tune.
78/62 Stock to 108/96 Fun
That is what I was trying to convey. The 48 with a good tune makes the 96 run like it should. displacement and head work with the right cam and things get even more fun. I don't think a 107 making 125/130tq is all that much more stress on the bottom end providing you don't beat the hell out of the bike.
Old May 27, 2020 | 01:36 PM
23Seven's Avatar
23Seven
I have a lot of time to figure it out. I’ll change my mind 100 times before this top end ever wears out.
Old May 27, 2020 | 01:57 PM
sanman4ever's Avatar
sanman4ever
You'll have that thing built up way before the 3-4 year time frame you've given yourself!
Old May 27, 2020 | 07:21 PM
eaglefan1's Avatar
eaglefan1
If you beat the hell out of it, dumping the clutch, burnouts, something will break for sure.
Granted I read some of the crank issue threads before I did my 106 kit. Knowing how I am, I didn't even measure the runout, if it wasn't perfect I would have constantly worried about it. Ive put over 20,000 miles on it since the kit install and all has been good. I don't beat on it though. Some roll ons sure, but it doesn't go above 4500rpms very much. Im knocking on wood as I type this.
Im sure some of these stock cranks are made, assembled, better than others. For every crank that has gone bad how many have not?
Old May 27, 2020 | 08:51 PM
ULTRA ZOOM's Avatar
ULTRA ZOOM
So 23seven , Who did your dyno tune ?
Old May 27, 2020 | 09:11 PM
1993FXSTS's Avatar
1993FXSTS
I'm suffering from the same dilemma. I am at a "Stage 1" 96 (extremely low mileage) and am planning to add a Woods 222 cam and a tuner. Eventually I want to go up to 107", but a friend of mine is an Indy and builds a lot of hopped up Harleys. He has had no problems with stock cranks up to 103", but at 107" he has had a few scissor. Granted these bikes were beat on, but I am leaning toward a built bottom end. If I do that, I might as well go BIG (?) cu in!
Old May 28, 2020 | 01:21 AM
23Seven's Avatar
23Seven
Bob and RC Cycles knocked it out the park.
Old May 28, 2020 | 01:23 AM
23Seven's Avatar
23Seven
I’m really pretty content with it right now and have no problem running this top end until it starts acting up.
