Four point docking hardware?
Old Jun 3, 2020 | 09:42 AM
96zjlimited's Avatar
96zjlimited
4th Gear
Default Four point docking hardware?
Hey everyone. Tried searching but ran short. Bought a new to me 05EGC. It has a four point mount/docking station and your pack on it. Got and function is fine. The thing I’m trying to figure out is the mounting pattern itself? I have my bike next to a co workers. The distance front to rear on my docking points Is shorter then his. Is this a model year thing or a design thing? All racks I see are for 09 later?
Old Jun 3, 2020 | 10:47 AM
jimglassford's Avatar
jimglassford
There were changes but not knowing your coworker's model or year makes the comparison difficult.
Old Jun 3, 2020 | 11:00 AM
96zjlimited
4th Gear
His is an 11 road king I believe. It appears to be a 09 model year change?
Old Jun 3, 2020 | 11:16 AM
Lunchboxx's Avatar
Lunchboxx
I think it was 09 when it changed not 100% sure. I had an 01 Road Glide and had sissy bar and luggage rack. Neither will fit my 15 ultra limited.
Old Jun 3, 2020 | 11:28 AM
96zjlimited
4th Gear
That’s kind of what I’m seeing. I assumed the four point would be universal. But it appears I need to find an 08-older rack
Old Jun 3, 2020 | 11:39 AM
dawg's Avatar
dawg
Four point docking began in 09. 2008 back to 1997 uses different docking hardware, specifically the 53803-06 and 53804-06 docking point hardware kits for either solo or two up setups.
Old Jun 3, 2020 | 11:45 AM
96zjlimited
4th Gear
That makes sense. I have no idea what is on mine then? It is a four point dock, but the length between the pins is certainly different then the 09+ hd version
Old Jun 3, 2020 | 03:49 PM
dawg's Avatar
dawg
You have both the 53803-06 and 53804-06 docking kits allowing you to run a tour pak or upright or solo setups.
Old Jun 4, 2020 | 10:59 AM
96zjlimited
4th Gear
I already have a dock on mine. I was trying to determine compatibly with racks etc as it measures different then the oem version I’ve seen
Old Jun 4, 2020 | 01:13 PM
svarnster's Avatar
svarnster
ride it to the dealer and see if they can match up the 2 pieces
