Estimated DYNO numbers
Old Jun 4, 2020 | 01:27 AM
Domjr's Avatar
Domjr
Stage III
Default Estimated DYNO numbers
Hello everyone, I'm new to the forums and want to get anyone's opinion on what they think my estimated HP & TQ number would be with what I have done to my bike so far. I can't afford a DYNO as of now so but I will be getting it done next year when I get back. So lets hop to the description, I own a 2014 FLHP with a SE Ventilator Elite Intake, a bassani road rage 2 into 1, Andrews 54H Cams, Knight Prowler tappets, SE adjustable pushrods, I also installed larger injectors but I don't emberm the size (I'll look it up when I get home)
I'm also looking for more upgrades I do to make more power other then get bigger heads. Thanks for your time gets!!
Old Jun 4, 2020 | 03:24 PM
Buelligan666's Avatar
Buelligan666
Did you just randomly pick all this stuff, or did you use a reputable shop to put a setup together for you? Why the larger injectors? Do you have a tuner? Doing all that without a tune, you're probably at stock hp, maybe less. It desperately needs more fuel. Get back from where? Have you been riding the bike this way?
Old Jun 4, 2020 | 06:01 PM
roussfam's Avatar
roussfam
What is 90Hp and 100ft/lbs Torque Alex?
Old Jun 4, 2020 | 11:13 PM
Domjr's Avatar
Domjr
Stage III
I had a shop in MD do the work
I went with larger injectors to try to get a little more HP
Currently using the Thunder Max for tunning
Not sure if all the Bassani 2-1 use wide ban O2 but I am running them as well
I'm getting an all expense paid trip the Bahrain courtesy of your local USMC
And yes I have put almost 10k on the bike since I had this done.
Old Jun 4, 2020 | 11:15 PM
Domjr's Avatar
Domjr
Stage III
Jez I hope its getting a little better then that haha
Old Jun 5, 2020 | 11:55 AM
FLS103's Avatar
FLS103
I will say 92 HP and 110 torque when properly tuned
yso191
Exhaust System Topics
13
Apr 3, 2024 04:41 PM
ultraclassic53
Nov 17, 2012 08:36 PM
harley_jeff
Aug 25, 2012 09:39 AM
patriotmc
Nov 29, 2009 04:24 PM
MiniMe
May 30, 2007 08:02 PM
