Ignition STUCK
Old Jun 17, 2020 | 10:43 PM
tberg725's Avatar
tberg725
Default Ignition STUCK
I have a 2017 SG I installed my paul yaffe bars which required me to pull the ignition switch that you spin in order to start the bike when I pulled it out the ignition it was in the off position I turned the key to the left and pressed in the button which allowed me to remove it, upon installation I put it in the same way I took it out but when I spun it into the lock position after install its now stuck in the lock position and have tried messing with it but it wont budge from the position, I'm not sure on what to do I can put the ket in and turn it and it does nothing
Old Jun 18, 2020 | 04:23 AM
kojak's Avatar
kojak
you’re ignition switch is misaligned. Did you turn the key before you rotated the switch?
Old Jun 18, 2020 | 09:50 AM
chopper_man's Avatar
chopper_man
Yup, as above, misaligned. Need an alignment tool or some have used a long flat-blade screw driver. FYI, in case you need to go back in there again, you do not need to remove the ignition switch to do the bars. There is a notch cut in to the plastic cover, slides right off.
Old Jun 18, 2020 | 10:15 AM
Vernal's Avatar
Vernal
Here's a good video on ign switch.
Old Jun 18, 2020 | 01:27 PM
tberg725's Avatar
tberg725
Yeah unfortunately I know this now idk why the instructions from yaffe said to remove it seemed dumb as i was pulling the fairing off
Old Jun 18, 2020 | 01:33 PM
tberg725's Avatar
tberg725
https://youtu.be/7-QBH1SFyzo
dude you're a lifer saved in this video is exactly what I did the wrong way and my ignition is currently stuck the same way smh
Old Jun 21, 2020 | 02:29 PM
tberg725's Avatar
tberg725
Forgot to post in here I was able to get the ignition off and use a flat head screw driver to line everything up took 5 minutes and was done
T-town Pig
Jun 20, 2019 11:09 PM
Ashnic
General Topics/Tech Tips
14
Jun 6, 2019 11:37 AM
Rzrback
Apr 28, 2016 06:04 PM
NewJackCiti
Apr 9, 2014 01:46 PM
flhxmc
Feb 22, 2013 09:53 AM
