Good shocks suck now?
Old Jul 6, 2020 | 02:59 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Puglia10
Maybe it is the angle, but I think the 08 and 18 are at pretty similar angles. I am just surprised at the difference between the two. They were perfect on my 08. Much smaller tire sidewall and harder seat probably aren't helping soften any blow either, but it's definitely mostly the rear shocks.
I think they're too rigid right now. Haven't had a chance to adjust them any yet. Hoping I can get them as good as the 08 felt...I would think so.
Set the sag so that it's correct. Ride it. If you don't like it try going down 3/8' (10mm) and see if it helps. If that don't help try going up 3/8" and see how it does. I find going up or down small amounts really doesn't give me a good feeling as to whether things are getting better or worse. I can fool myself. If it's crappy both ways, the shock are not set up correctly, springs or damping.
Old Jul 6, 2020 | 09:41 PM
Then Came Bronson's Avatar
Then Came Bronson
Originally Posted by Streetrunner
The front suspension is different on the 2018 compared to 2008. That may make a difference on the overall ride when interacting with the rear.
This.
Was your front suspension stock on the 2008, or did you change that too? If everything is stock, I'll pile on the bandwagon to reset up your rear suspension on the new bike. Start from scratch, and reevaluate from there.
Old Jul 7, 2020 | 10:59 AM
Puglia10's Avatar
Puglia10
Originally Posted by Then Came Bronson
This.
2008 front end had racetech springs and ricor intiminator valves, so thats definitely part of it I'm sure. But just the rears alone on the 08 were better than this so Ill definitely start over and reset the sag for the 2018 and go from there. Im sure Ill do the front eventually.
JHC210
Milwaukee Eight (M8)
20
Jul 20, 2020 11:42 PM
AlanStansbery
Mar 14, 2013 08:33 PM
iamrockinrich
Nov 29, 2012 06:12 PM
balloo
Jun 12, 2012 12:06 PM
eddieo
Jul 10, 2009 01:32 PM
