Street Glide Peeps - Replacement stubby antenna
Old Jul 21, 2020 | 05:55 AM
sumncguy's Avatar
sumncguy
Default Street Glide Peeps - Replacement stubby antenna
Morning,
Ive heard of some folks using the Pep boys and other reasonably priced replacement stubby antennas. Anyone got a make, model, part number ??
Thanks in advance for the help !!
Old Jul 21, 2020 | 06:44 AM
Iceman24's Avatar
Iceman24
As long as you get the same base/mount (std antenna), anything will work. Amazon has tons...check the ratings. One thing to consider is where you ride. Back when I had my '09 FLHX, I swapped stock/whip f/ HD shorty, but didn't like the pole jutting out on back...always in the way. I ended up installing HD Boom Hidden under fairing & adding "Y" connector w/ a 2nd short antenna, also under fairing. This really added great reception...just a thought. Good luck!
Old Jul 21, 2020 | 06:45 AM
Pothole914's Avatar
Pothole914
This is the one that I use. Works great.
Amazon Amazon
Old Jul 21, 2020 | 07:10 AM
702's Avatar
702
Old Jul 21, 2020 | 08:05 PM
Pothole914's Avatar
Pothole914
Originally Posted by 702
Is that an actual antenna? If so, source, I want one. LOL
Old Jul 21, 2020 | 08:16 PM
702's Avatar
702
Here ya go....
Amazon Amazon
Old Jul 22, 2020 | 05:56 PM
gregski's Avatar
gregski
Check YouTube for "Harley antenna relocation". That is what I did on my Street Glide. Keeps the same antenna, but it gets tucked up along the frame. Then bought a plug to fill the hole. Cheap and easy.
Old Jul 22, 2020 | 07:07 PM
langwilliams's Avatar
langwilliams
I just got this one https://www.ebay.com/itm/13-Spiral-M...72.m2749.l2649
don't know if I'd consider it "stubby" but it gets good reception....I had a longer plastic one on an this one works way better. I had a long chrome on on for a while to get decent reception an the one I just got works almost as well.
Old Jul 22, 2020 | 09:40 PM
Pothole914's Avatar
Pothole914
Thanks, be here Friday.
Old Jul 23, 2020 | 07:54 AM
AZBadgerFan's Avatar
AZBadgerFan
Agreed, I did the same and used this video and it took maybe 15 minutes. Tried a couple of replacement antenna's purchased off Amazon and at Auto Zone and neither worked well.
