Feather Lever
Old Nov 24, 2020 | 08:29 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by VAFish
Yeah, Rekluse is another very viable option. I have a friend who has one on her trike and loves it. But Rekluse is $250 more before installation. and the Installation is much more involved.
A Rekluse does cost more and the more involved installation is debatable. But one thing is for sure, the extra money spent on the Rekluse (in my opinion) is head and shoulders better; it takes clutch pull out of the equation.
Old Nov 24, 2020 | 10:56 AM
hattitude's Avatar
hattitude
I'd also go with the Rekluse clutch option...
This Feather Lever unit is unique and ingenious... but it sure looks to be a complicated answer to the problem. Every fitting/hose connection is a potential leak point..
I DO NOT like that it is attached to the oil pressure system of the engine and gets its "power" from that system... As seen with the early sumping issues with the M8, and the pre-production sumping issue with the Twin Cams (that was fixed prior to production), these Harley V-Twin oiling systems seem to be a have critical balance between pressure and scavenging... I don't want any other burdens on that system, outside the original design parameters...
The Rekluse solution is a win/win... no NEED to even use the clutch, and a better than OEM clutch to boot... The install of a clutch really isn't all that hard.. or time consuming for a pro to accomplish if paying for it to be installed...
Kudos to Feather Lever for a clever, unique invention, but I'd pass....
Old Nov 25, 2020 | 10:40 AM
VAFish's Avatar
VAFish
My concern with the Feather Lever was more if one of the hoses breaks or cracks while you are riding and it pumps all your oil out onto the road and your engine seizes up.
I've changed clutches in a Sportster, it was pretty easy. Haven't tried it on a Big Twin touring bike yet. But my understanding of the Rekluse you are still supposed to pull in the clutch to change gears.
Old Nov 25, 2020 | 10:57 AM
RKZen's Avatar
RKZen
Also just wondering how much additional oil is needed to power the unit.
This or the other brands of automatic clutches would be better.
Old Nov 25, 2020 | 12:18 PM
Yee Hog's Avatar
Yee Hog
That does nothing to get rid of arthritis. The Feather Lever won't get ride of it either, but it won't make it hurt as much.
I went from a 2006 Sportster to a 2019 Ultra Classic and I can't believe how much harder the clutch is on the Ultra. I used a scale and strap to measure the force on the clutch lever, it's 25 lbs on the Ultra, My daughters 1997 Sportster Was a couple pounds less, but when I pulled the clutch all the way back to the bar, like you would while waiting at a stoplight, it dropped to 15 lbs, the hydraulic clutch remains constant.
Harley did a crap job with their hydraulic clutch. I was at my local dealer a couple weeks ago, they had a Kawasaki Z900RS Cafe that someone had traded in on a Livewire. I sat on it and pulled the clutch lever, it was so easy I thought something was broken. But nope, just a well designed clutch.
VAFish, This is not normal. I have a 1999 Road King with a standard cable clutch after lubing the cable it's a dream to use for about 10K miles before I repeat the process. I also have a 2016 Ultra Classic with a hydraulic clutch. The hydraulic clutch is also smooth as butter. I think yours needs a good inspection to see what's wrong.
Old Nov 27, 2020 | 05:58 PM
rockher_man's Avatar
rockher_man
Default Clutch pull.
Huh....the cable operated clutch on my 1979 FLH
is a 2 finger pull all day & night.....😏
Old Dec 1, 2020 | 05:13 AM
ofan's Avatar
ofan
Default SoftBrake Clutch Lever
I had Ulnar Nerve Surgery this year and the Hyd clutch on my 2014 SGS aggravated it. I bought the Softbrake reduced reach lever and it has been great. Once I received my lever in the mail I had to send them my old one. He modifies them. When I first got my bike I bought a longer better rear brake pedal from them as well. Great stuff and super nice people.
SoftBrake Company
28755 N. Silver Meadows Loop
Athol, ID 83801
(208) 561-5031
Old Dec 3, 2020 | 07:13 AM
MCSarge's Avatar
MCSarge
Like a lot of people I hated the clutch pull on my new RGS. I have friends that have the new levers that you can adjust and I didn't care for the look of them, plus they were 240.00. I have a hydraulic clutch on my 07 CVO Springer and it doesn't have the problem this one does, it pulls fine and starts to catch about a 1/2 way off the grip. So I broke down and for 256.00 bought the AIM Gen 2 clutch slave cylinder. Keeps the factory look on the bars and was easy to install. Bonus, I can now pull the clutch lever with 2 fingers and it starts to engage about 1/2 way off the grip instead of at the end like the factory slave cylinder...
Old Dec 3, 2020 | 09:19 AM
Old_Bikes's Avatar
Old_Bikes
I installed a AIM VPC (variable pressure clutch) and was surprised by how much it reduced the lever pull. I installed it for the increased clutch pressure, but this was not a bad side effect. This was on a 2013 RK with cable clutch, but I would think the same result would be gained on a hydraulic clutch. I have been thinking about installing one in the 2014 Limited (hydraulic) but have not needed it and don't want to spend the money for no real reason.
limitedNH
Milwaukee Eight (M8)
Jul 10, 2020 10:51 PM
paid4c4
2014-2024 Touring Models
Apr 13, 2018 10:23 AM
WG2011
Mar 31, 2015 09:24 PM
michigan hog
Jun 30, 2013 09:44 AM
Bankrupt
Exhaust System Topics
Apr 11, 2011 05:36 PM
