T
Old Jul 26, 2020 | 10:21 AM
ClubstyleRG905's Avatar
ClubstyleRG905
Stage I
Default T
Hi Guys,
I have almost completed the installation of the following
New thundermax tuner
New Trask Air cleaner
New Trask 2-1 Exhaust
New Kraus Risers with MX bars and new Top triple tree
There was a spot on the stock oem triple tree for the ground. Now I dont have the gounds hooked up and the bike keeps popping the 5A fuse for Acc!!
Do I need those, I think I do.
Also where can i mount those 2 grounds that used to go inside the necel(which i no loger have) and triple tree?
Any help is greatly appreciated.
Thanks Guys!
Old Jul 26, 2020 | 01:03 PM
bdtaylor1979's Avatar
bdtaylor1979
I would start by hooking up the grounds. They are there for a reason.
Old Jul 27, 2020 | 03:02 PM
grbrown's Avatar
grbrown
Simply recreate the ground points that you no longer have. Choose a location on the new tree to drill a suitable hole, where you may be able to connect all the grounds that don't have a home at present. You could even connect them all together and add a large section extra wire to a single ground point.
Ian Meinert
Aug 21, 2018 06:29 PM
deedz
Sportster Parts
Mar 29, 2017 09:54 PM
klf33
May 3, 2013 10:09 PM
adambamburg
Mar 27, 2011 06:41 PM
I CUT 1
May 11, 2010 03:47 PM
