02 Road Glide front wheel
Old Jul 27, 2020 | 10:16 AM
milunchbox's Avatar
milunchbox
Default 02 Road Glide front wheel
I want to swap my front wheel for something different hopefully bigger. Does anyone know what other Harley front wheels will be direct replacement?
Old Jul 27, 2020 | 10:42 AM
EVOrider's Avatar
EVOrider
Bigger? What size are you interested in?
Keep in mind though....going to a drastic change in tire heights....can change the lean on the Jiffy stand.
Old Jul 27, 2020 | 10:44 AM
caulk04's Avatar
caulk04
Ugh. Wheel size doesn't have to affect tire diameter until you get over ~19" wheels.
I don't know enough about the wheels on models that early, so I can't tell ya much. I think to go with anything newer/newish you're going to have to convert your brakes to the Brembo stuff from 07+.
Old Jul 27, 2020 | 11:43 AM
tfi racing's Avatar
tfi racing
Head over to the wheel and tire section. All the answers you need and more,almost any wheel can be fit with the correct combo of axle,bearings and spacers and some will require the newer Brembo calipers as well.
Old Jul 27, 2020 | 11:47 AM
milunchbox's Avatar
milunchbox
I would like a really good looking 19"
Old Jul 27, 2020 | 12:39 PM
EVOrider's Avatar
EVOrider
Easy then.....you currently have the 0ne inch axle. It was used up to 2007. You can reuse your axle and spacers.
They went to 25mm in 2008+.....you’ll need the axle plus spacers. Basically, set it up to copy the later models. Different wheel, bearings, brembo calipers and disc.....etc.
I put 2010 front wheel plus Brembo configuration on my 1998 Ultra.
soonerpete50
Jun 21, 2020 09:39 PM
Sticky4
Touring Parts
Jan 17, 2020 05:42 AM
6wolfman9
EVO
Sep 8, 2018 05:49 AM
01dyna
Aug 19, 2012 11:20 AM
Gofer
Feb 20, 2010 10:34 AM
