Ciro Highway Peg Install
Old Aug 2, 2020 | 10:16 AM
SigPiLocal's Avatar
SigPiLocal
6th Gear
Default Ciro Highway Peg Install
I just started working on this, and the 5/16'' hex bolt that is mounted to the frame seems to be locked to hell. Any suggestions for getting it out? Heat? PB Blaster?
It's a 2020, so there is no bolt on the backside, it's threaded into the frame
Old Aug 2, 2020 | 11:11 AM
wildtxn's Avatar
wildtxn
I had to put heat to mine to loosen the loctite that is most likely on it stock. It will eventually come out.
Old Aug 2, 2020 | 01:16 PM
SigPiLocal's Avatar
SigPiLocal
6th Gear
Thanks, think hair dryer is enough or will i need to get a heat gun or flame? Should i worry about the black painted frame?
Old Aug 2, 2020 | 02:15 PM
barneyboy's Avatar
barneyboy
If you're concerned about the paint, hold the tip of a soldering iron to the bolt for a bit. The heat will soften the loctite without damaging the paint.
Old Aug 2, 2020 | 04:18 PM
skratch's Avatar
skratch
also, when backing out the bolt, don't just lefty-loosey it all the way out. back it off a little, then run it in a little, alternate that until it's either out, or you can tell that there is nothing binding.
Old Aug 2, 2020 | 04:56 PM
SigPiLocal's Avatar
SigPiLocal
6th Gear
Ended up getting it out! I bought longer breaker bar and was able to get it free!
rheimy
Aug 6, 2020 01:30 PM
FrankEV
General Topics/Tech Tips
16
Jul 29, 2018 11:40 PM
The Savage Rabbit
May 19, 2012 09:45 PM
dwg dave
Mar 25, 2010 07:59 AM
bensonjv
Sep 21, 2006 03:36 AM
