Milwaukee 8 engine temperature
Old Aug 14, 2020 | 06:46 AM
Socalledchad's Avatar
Socalledchad
Default Milwaukee 8 engine temperature
What kind of temps are others seeing ?
Looking at my powervision I see head temps upto 400 and engine temps up to 380. Normally only see it get this hot on a long stretch of freeway on a hot day. My bike is about to hit 30k miles..so it must not be to hot. 19 sg 107
Old Aug 24, 2020 | 11:58 AM
Peace Frog's Avatar
Peace Frog
My 2018 FLHTK engine temperature hits 275 on a regular basis in 100+ degree outside temperatures and the heads hit 300-310 at 100+ outside temperatures. Those temps are from the Power Vision PV-2 mounted on the handlebars...
Old Aug 24, 2020 | 01:50 PM
Naz's Avatar
Naz
Never had a cylinder head temp gauge on any of my bikes and haven't ever seen a max spec for a Harley. Of course a H-D max operating temp would govern but 400-deg does not sound unreasonable to me based on piston powered aircraft I've flown. A 310HP air cooled aircraft engine normal operating range can go up to 480-deg and run like that all day and into the night and not be a problem. Aircraft specs are generally very conservative. So if you can't find a definitive max operating temp from H-D, this could give you a point of reference.
Old Aug 24, 2020 | 01:59 PM
smitty901's Avatar
smitty901
SG/RG is oil cooled head not coolant . They will run a bit hotter than the full touring bikes with Coolant and lowers . With sidecar head temp 260-280 are normal. Real hot day in traffic 300 can be seen but never an issue. My older non wet heads would hit 360.
Old Aug 24, 2020 | 02:00 PM
Keithhu's Avatar
Keithhu
Obsessive compulsive behavior begins when you start measuring things.
Old Aug 24, 2020 | 03:51 PM
Socalledchad
Oh noooo..this means it started many years ago as a teenager. do you think its to much ? I've gotta do something about this immediately.
Old Aug 24, 2020 | 03:53 PM
TriGeezer's Avatar
TriGeezer
Only motors with temperature gauges over heat.
Old Aug 24, 2020 | 03:55 PM
ajtwin's Avatar
ajtwin
Interesting!!
Can you tell me what engine?
Old Aug 24, 2020 | 04:23 PM
Naz's Avatar
Naz
Lycoming TIO-540-AJ1A. I flew Turbo Stationairs when I was doing SAR work. The N/A versions are popular with the bush pilots in Alaska as they'll carry about anything you can load through the clam shell cargo doors. Also flew that model with a STOL kit which I hated on windy days and it's always windy up here in Northern AZ and it didn't have oxygen so limited our missions up here in the high country. But was outstanding for longer range missions down near the Mexican border looking for Cartel smugglers south of I8.
Old May 27, 2023 | 01:42 PM
smitty901's Avatar
smitty901
My 2020 wet head. ET tends to run 70-90 degrees hotter than the Coolant temp once warmed up .
