Tour pack docking
Old Aug 27, 2020 | 02:45 PM
tajar66's Avatar
tajar66
Default Tour pack docking
anyone have experience with this docking kit. I was looking at the Hogworx parts as well.
Amazon Amazon
Old Aug 27, 2020 | 04:02 PM
Quicksilver55's Avatar
Quicksilver55
Amazon Amazon
My 2 cents stay with the harley parts.
Old Aug 27, 2020 | 05:36 PM
tajar66's Avatar
tajar66
i would but the kit for 2013 FLHTK is discontinued.
Old Aug 28, 2020 | 08:11 AM
RKZen's Avatar
RKZen
The H-D conversion kit is 53246-09A, might be 53246-09C now, but I don't think it's discontinued. Call some of the online H-D stores like Surdyke. Some may have them backordered 'til Sept.
Old Aug 28, 2020 | 11:47 PM
tajar66's Avatar
tajar66
thank You
Old Aug 29, 2020 | 10:05 AM
rcn1963's Avatar
rcn1963
If you are just looking for a way to mount/remove a tour pack, then another option would be to look for someone getting rid of the stock tour pack mount. I used to use the QD docking kit to mount the tour pack. But I found I can install/remove it almost as fast with the stock mount. And the stock mount NEVER rattles.
Of course, if you are also wanting to mount other stuff like a passenger backrest or luggage rack, then you will need the qd mount. But even then, I leave the qd mount attached to my luggage rack and swap it out using the mounting bolts. If you end up having to adjustment the cams at all to get rid of a rattle when you do a swap, then I'd bet using the stock mount is just as fast.
Just pointing out an option.
Old Aug 29, 2020 | 03:56 PM
zapshd's Avatar
zapshd
I agree totally with the previous post. My docking hardware always made my tour pack rattle and move slightly no matter how I adjusted the oblong bushings. The permanent rack mount comes off with 4 bolts without having to remove saddlebags and is so much sturdier than the docking hardware.
Old Aug 29, 2020 | 06:00 PM
tajar66's Avatar
tajar66
Good to know. I hate rattles.
Old Aug 30, 2020 | 01:23 PM
RKZen's Avatar
RKZen
I've had my H-D 4-point docking hardware since I bought my '13 King new. I take my TP on and off often, as well as my luggage rack and backrest. Never had to adjust the mounting points and no rattles so far.
A buddy had aftermarkets and those did rattled after a couple years. He now has the H-D and no rattles so far in 5 years.
Old Aug 30, 2020 | 02:32 PM
rcn1963's Avatar
rcn1963
I was able to get it to stop rattling using the adjustments. But it would start again within 500 miles or so. It's possible that I wasn't tightening them enough...but I was cranking hard enough to be concerned about stripping it.
The other headache was that the correct oval positions for the tour pack and luggage rack were different. That meant they had to be adjusted every time I swapped them. Now I leave the docking hardware connected to the luggage rack, and the stock mount attached to the tour pack. 4 bolts and I'm done...with nothing to adjust.
