Engine swap
Old Aug 31, 2020 | 04:48 PM
Richard Gromowsky's Avatar
Richard Gromowsky
1st Gear
Default Engine swap
Hey new here but had a question. I bought a wrecked 2017 dyna with screaming eagle 110 and wanted to put that engine in my 2010 street glide. Will it change over.
Old Aug 31, 2020 | 06:01 PM
roussfam's Avatar
roussfam
You bought it and NOW you want to know if it will fit
Old Aug 31, 2020 | 06:27 PM
hd king's Avatar
hd king
Yep it will swap over. They are both 07-up alpha engines.
Old Aug 31, 2020 | 07:47 PM
Richard Gromowsky
1st Gear
I bought it to buy it. I have three bikes because I like them. My streetglide started blowing smoke so I want to swap engines while I rebuild my streetglide.
Old Aug 31, 2020 | 08:23 PM
Notgrownup's Avatar
Notgrownup
Little JB weld...
Old Aug 31, 2020 | 09:56 PM
dickey's Avatar
dickey
I don't believe the Dyna motor will swap to the touring platform...the tranny mount & primary is different. Not 100%, but pretty sure.
Old Aug 31, 2020 | 11:55 PM
hd king's Avatar
hd king
​​​​​I've done it. 07-up twin cam alpha engines come in dyna and touring models. You can't swap inner and outer primary's but everything inside except the chain can be swapped.
Old Sep 4, 2020 | 11:20 PM
Richard Gromowsky
1st Gear
Default Let's do it
Well I've pulled both engines so I will let you know. Only way to see if it will work is to try it out. Thanks for the input and I'll keep you guys updated..
Old Sep 5, 2020 | 04:57 AM
Campy Roadie's Avatar
Campy Roadie
Front head will need to be drilled and tapped for the touring engine stabilizer mount.
Old Sep 5, 2020 | 06:08 AM
Kawickrice's Avatar
Kawickrice
I think it is the Softail tranny mount that wont work on dynas and touring
