Help with - Fly by wire- throttle sensor replacement
- I purchased a 2011 road glide with a set of ape hangers,,,, I replaced the bars with standard reach bars,,, when I did I obviously had to rewired the throttle sensor in ( it was JUST the white plastic sensor that fit in a notch in the end of the bar )
- now the sensor is very worn and feels " notchy, " so most all are telling me it's a common issue and replace it ,,
- question -
All the replacement sensors have a long metal tube attached to the white plastic sender at the end,,,, mine only had the white plastic sensor ,, not the metal tube ,,,, help I'm confused ))) what is the correct part #,
What does this ( replacement ) part look like ?
Will I have to buy one with the big fly by wire sensor attached to this metal tube and remove it ????
Thank you
lol
i had to ask for the new version.
