tour pack liner
Old Sep 23, 2020 | 05:16 AM
leadman's Avatar
leadman
Default tour pack liner
My tour pack liner doesn't lay flat all the way around the top of tour pack .
I'm wondering if a little heat & then clamp till cool will flatten it out ? I've
tried velcro but it doesn't help . I know it's minor , but it bugs me .
Old Sep 23, 2020 | 07:43 AM
cruzomatic's Avatar
cruzomatic
3M Super 77 Adhesive Spray would work well for that. It's very tacky.
Old Sep 23, 2020 | 10:35 AM
leadman's Avatar
leadman
That might cause a problem if I ever have to pull liner out to get to
wiring or lighting .
Old Sep 23, 2020 | 10:53 AM
RKZen's Avatar
RKZen
A buddy of mine had the same issue on his king TP liner on the left side and back. He uses the velcro trick and has not had any issues going about a year now.
However, he did use a little heat prior to the velcro. He used a homemade jig to prop the affected sides outward and applied heat via a blowdryer. This method made the sides fairly straight.
Old Sep 23, 2020 | 11:38 AM
handirifle's Avatar
handirifle
If you use heat, use a hair dryer, and NOT a heat gun. These bags are ABS and it softens at around 220*F. Personally, I would use the hair dryer, and just use a gloved hand to press and hold it. Shouldn't take but a min or so to cool enough to hold the new shape.
I saw a show where a guy was making felt hats, and they used steam machines, to heat, then shaped the hat.
Old Sep 23, 2020 | 11:50 AM
leadman's Avatar
leadman
The bag is ABS , but what is the liner made out of ? Fiberglass & felt ?
Old Sep 23, 2020 | 11:51 AM
leadman's Avatar
leadman
I think I'll try a hair dryer & not a heat gun .
Old Sep 23, 2020 | 11:55 AM
RKZen's Avatar
RKZen
Yup hair dryer is what I meant...and that's what my buddy used.
Old Sep 23, 2020 | 03:23 PM
handirifle's Avatar
handirifle
I believe felt only.
Old Sep 24, 2020 | 05:13 PM
IKnowNot's Avatar
IKnowNot
The liner that came with my FLHTCU is some type of black plastic skinned with something that looks like felt.
