Starting Issues 2020 FLHTK
Old Sep 29, 2020 | 10:13 PM
julesdain's Avatar
julesdain
Veteran: Canadian Forces
Here's my 2020 FLHTK, it looks the same and there are other connectors that are the same. Sounds like it was loose. I've washed my bike a few times as well but have not had any starting issues
Old Oct 1, 2020 | 02:06 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Good tip on the ACR. Try applying some Dielectric grease around the connector to prevent water intrusion.
Old Oct 3, 2020 | 03:40 AM
lionsm13's Avatar
lionsm13
Originally Posted by dlwarre
And the answer is,, Harley Davidson manufacturing QC failure.
Solenoid Cable notice the wire and the partial wire protector falls short of going directly to the clip. This allowing moisture to enter the connection.
Removed the cable, inpected it for water or damage and re-plugged it in, bike started.
I will have to find a way to create a protector for this wire.
Thank you for everyone who tried to help.
My first thought was moisture. Why can't you use Dielectric grease, or tune-up grease, which is a silicone-based grease that repels moisture and protects electrical connections against corrosion. It is also used to keep dirt, water, and other elements out of electrical connections. It has many uses, including automotive tune-ups, home electrical work, and recreational vehicle wiring.
