07 Harley rear wobble
Old Oct 8, 2020 | 02:01 PM
eighteight's Avatar
eighteight
Originally Posted by miketv84
Ok cool. I heard the rubber bushings go bad ?
FWIW I replaced mine @30K miles
They were distorted and the metal plate were "shifted"
Old Oct 8, 2020 | 02:14 PM
miketv84's Avatar
miketv84
Interesting. I found a set of polyurethane ones a little more expensive than harley stock ones. Think it's worth it ?
Old Oct 8, 2020 | 04:27 PM
eighteight's Avatar
eighteight
not sure we are talking same part or model year
i replaced OE number 47564-86
Old Oct 8, 2020 | 04:30 PM
miketv84's Avatar
miketv84
Yeah your part number is what I was originally looking at from harley for my 07. Thought maybe the polyurethane might be a better option ?
Old Oct 8, 2020 | 04:35 PM
eighteight's Avatar
eighteight
cant say
used stock
others may weigh in
Old Oct 9, 2020 | 02:07 PM
eighteight's Avatar
eighteight
The part you show replaces o.e. 48487-02 Under $6 each from Moco
Old Oct 9, 2020 | 04:21 PM
eighteight's Avatar
eighteight
The part you show replaces o.e. 48487-02 Under $10 from Moco
As the part number indicates that is a “ spacer” not present before 02 model year ( not “ there” on my 99)
I m suggesting the outboard rubber isolators as referenced in earlier post
Old Oct 9, 2020 | 08:36 PM
bigskyroadglide's Avatar
bigskyroadglide
Ok thanks. Bearings or those rubber isolators hardly go bad? I managed to get the air properly adjusted in the tire just now.
An 07 does not have swingarm bearings unless someone has replaced them.
From the factory the 07 swingarm comes with something called a cleave block inside the swingarm. The replacement which will eliminate the wobble is a bearing and is a popular replacement from glide pro and/or stay bo
Old Oct 9, 2020 | 08:37 PM
bigskyroadglide
Call Kevin at sta no. those bushings indicated in the picture fit inside the rubber bushings from Harley.
Old Oct 10, 2020 | 06:54 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There most certainly are roller bearings in your swing arm, that’s what part 9208 is. One on each side.
The Sta-Bo II bushings go into the oem frame mounts (47564-86B), they do not replace them.
steering head wear in going to create wag that will feel like bikes rear is swinging in a turn, and builds up gradually in the normal course of time. I would suggest you check this.
