Street Glide spring preload
Old Oct 23, 2020 | 04:45 PM
Reverend DG's Avatar
Reverend DG
Default Street Glide spring preload
So I just switched from Heritage to a 2019 Street Glide standard. I must be getting old, but the chart for setting rear preload makes no sense to me. Can anyone tell me how many turns to give it for a 180 pound rider with stock shocks, no tourpak, and no passenger? Much appreciated!
Old Oct 23, 2020 | 06:41 PM
Reverend DG
Ooops, nevermind. it suddenly made sense. I just didn't believe that 180lbs requires 0 preload.
Old Oct 23, 2020 | 06:44 PM
gonemad's Avatar
gonemad
I’m 220 and pre load mine to 0. Dang things are hard as bricks.
Old Oct 23, 2020 | 06:57 PM
Reverend DG
Yeah, I'm really noticing the difference between the SG and the Heritage with balloon tires!
Old Oct 24, 2020 | 04:01 PM
PoCoBob's Avatar
PoCoBob
I weigh 195 and based on the chart for my 2015 StreetGlide I should be set at 0 as well. Just for the heck of it one day I set them on 3 to see what the difference was. That was a couple years ago and I haven't changed it since. I don't know why but 3 is smoother than 0.
Old Oct 24, 2020 | 04:26 PM
OKIE17GLIDE's Avatar
OKIE17GLIDE
I haven't pulled the bags to check but are the 2 rear shocks connected? If you adjust the preload(left side) does it adjust the right shock also?
Guess my lazy a$$ could go look too!
Old Oct 24, 2020 | 04:27 PM
OKIE17GLIDE
Old Oct 24, 2020 | 04:37 PM
SWFLGuy's Avatar
SWFLGuy
I keep mine on 3 but when I have a passenger it goes to 18.
Old Oct 24, 2020 | 08:05 PM
Reverend DG
Thanks for all the answers. I'll try 3 just for the heck of it, but do you mean 3 clicks or 3 full turns?
As for the shocks being connected, sometimes suspensions are set up so that one side does compression and one does rebound. But in the this case we're talking spring preload, so I'm guessing yeah, you might be right about them being connected.
Old Oct 24, 2020 | 08:34 PM
PoCoBob's Avatar
PoCoBob
In my case I did 3 full turns which was 6 clicks. I've had my shocks off several times and there is nothing connecting them.
