Wiring question
Old Jul 29, 2007 | 09:18 PM
teach's Avatar
teach
Default Wiring question
I'm going to hardwire my GPS tomorrow through the accessory switch to the aux. connector under the seat. Of course the black is the ground but does anyone know if the red w/yellow strip or the solid red is the hot lead for the accessory switch? Never have a schematic when I want one, lol...
Thanks in advance......... T
Old Jul 29, 2007 | 09:23 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: Wiring question
Use your volt-ohm meter set to check 0-20 VDC and test each one against ground using the aux switch. I am pretty sure it's the red one, but, test to be sure.
Old Jul 29, 2007 | 09:44 PM
RandyNC's Avatar
RandyNC
Look in your owners manual, almost positive its the red wire.
Old Jul 29, 2007 | 10:41 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
ORIGINAL: teach
There are little pins in the accesory plug that you have to move in oder to get the plug to work from the switch. You have 3 options, Ign switch/hot, batter/hot or acc switch/hot. I looked for some paperwork I had that told about this, but I can't find it... but maybe it was in the owners manual.
Found this for you. https://www.hdforums.com/fwd.asp?messageID=1747270
GaugeMods
May 20, 2020 10:16 AM
als2052
Nov 27, 2013 12:23 AM
big TYME
Apr 15, 2013 10:30 AM
Rickr01
May 11, 2012 06:27 AM
jimsuver
Aug 21, 2010 04:33 AM
