Rerouted head breathers NO OIL on bike finally
There are many answers. I have no idea why but after 10K miles using amsoil, I no longer get blowby. I figure that something internal has broke fixing the blowby problem.
But if you want to never have oil on your leg, get a couple of 90 degree pipe fitting that fit, and run hoses tothe ground.
...gene
These are at J&P but there other places you can get them as well.
http://www.jpcycles.com/productgroup...All&page=2
http://www.jpcycles.com/productgroup...All&page=7
In the second link (which I use), I tried different brands.Found the glue that holds filter to bracket would break loose. So added my own bracket around
the filter and bracket, cured it. Used a piece of flat stock polished aluminum.
Older cars used to do that, we called them road draft tubes. They were discontinued and we started using the PCV (positive Crankcase Ventilation) system.
Which reroutes the blowby (natural combustion process by-product)
back into the intake system to be re burned.
HD in the Evo and newer motors put the PCV system in the head and rocker boxes. A mesh filter traps the blowby and a rubber umbrella seal regulates the flow out the ports in side of head behind A/C.
However, for various reasons (won't go into detail here) some bikes have more blowby than others. The excess mist is routed to A/C to be reburned.
But sometimes it is in excess and accumulates in the A/C and drips out,
then the air stream slipping by while you're riding deposits it along your pants and the bike.
HD does offer an upgraded pcv (umbrella and mesh filter system) on some bikes under a service bulletin.
Otherwise you can follow the links in my other post for acceptable exterior filter systems.
Does NOT matter what oil you use, you will have blowby, just maybe not as much.
If the umbrella seal breaks or whatever, you will get more not less blowby.
OK why? If you are getting blowby rerouting the hose out side the head will make ZERO diff on blowby.
...gene
