Best Electra Glide year
Old Dec 17, 2020 | 03:50 PM
lcaporaso's Avatar
lcaporaso
Hattitude! Great response.
Old Dec 17, 2020 | 03:51 PM
Mr. Mike's Avatar
Mr. Mike
E-F-I had a choice, I’d go with a carbureted model. Simple to works on if you don’t mind that sort of stuff. Too much gadgetry with FI.
Old Dec 19, 2020 | 06:19 PM
Markymannn's Avatar
Markymannn
Carb is easy to work on.
EFI you dont have to work on it.
Old Dec 21, 2020 | 01:37 AM
byersmtrco's Avatar
byersmtrco
IF you don’t change anything
Even the simplest mods (pipes & air cleaner)
require a reprogram on the ECM.
$$$$$$$ !!!!! Carb bikes don’t have
an ECM (YAAAAAY !!!)
FI bikes run leaner (hotter)
My FI 03 runs 20-30 deg (oil temp)
hotter than my 00 carbureted model
Elec fuel pumps fail, occasionally.
Gravity doesn’t. I stated recently
when my 00 was stage 1. The cycle shack
mufflers, K&N and a re jet would run circles
around the 03 with the very same mufflers the SE air cleaner (which is crap by the way) and a SERT download.
Just sayin’
Old Dec 21, 2020 | 10:05 AM
hattitude's Avatar
hattitude
I like a good carb bike too...
But.. If a one bike runs hotter than another... the cause is not because one is EFI and the other is a carb..
The combination of intake, pistons (type & displacement), cams, heads, exhaust, and tune are what decide the amount of heat from an engine....
A carb is a simple and proven device. When maintained and properly tuned, it will produce a very good running bike...
My '01 Springer w/carb fires right up as soon as I touch of the starter button... When it starts I always think, "Why couldn't I get my kick start bikes dialed in like this...???"
But to be fair, and honest, a good EFI (like the Delphi in the HD) can control far more throughout the tune map, and in more detail, then jets, needles, floats, and diaphragms.... there is no reason for the exact same bike, one with EFI and one with carb, for the EFI bike to run worse than the carb bike... unless it has a poor tune....
The key to both is a good maintenance and a great tune by someone who knows what they are doing... not always and easy thing to find for either choice...
Old Dec 21, 2020 | 12:32 PM
byersmtrco's Avatar
byersmtrco
Agreed.
The SERT tune was done at a Harley Dealer @ time of purchase
I want to pull that cam cover to check those shoes.
At that time, new cams might accidentally go in there (most likely)
Which will require a re-prog.
R&C Cycles in Hayward Ca will do it.
I've heard nothing but good about them. I'm sure they'll dial it
in right.
Other than being a DOG, it's a beautiful bike. Runs like a clock,
But these days when a 96" is small . . . . . .
Old Dec 21, 2020 | 01:11 PM
byersmtrco's Avatar
byersmtrco
This is the CVO I had in mind
04 ?
panz4ever
EVO
Mar 18, 2020 09:57 AM
kazanimo
Sep 19, 2019 04:50 PM
JonW
May 20, 2019 04:44 AM
dfowler1
Motorcycles For Sale
Jul 17, 2017 09:17 AM
papagino
Mar 29, 2017 11:42 AM
