Simple question about tire changing
Old Dec 21, 2020 | 06:24 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by Joe from So Cal
2016 Road Glide. I'm changing my back tire, installing an Avon. I like that I can examine everything and clean it up in that area as well.
My question is simple; do I need to put anything on the bead to keep it sealed? Will it seal as well as it always did before?
Be aware that Avon tires do not have a heavy mark on them, they claim there isn't a "heavy side" which isn't true in my experience. When I mount Avons I mark the heavy part of the rim on the outside, mount the tire and then shift the mounted tire on the rim and check balance until it either balances or nearly balances. That way I only use a small amount of weight.
Old Dec 21, 2020 | 08:43 AM
RKZen's Avatar
RKZen
I have Avons on my King. My Indy did the install and he doesn't do anything special, except use balancing beads.
Old Dec 23, 2020 | 04:10 PM
Joe from So Cal's Avatar
Joe from So Cal
Originally Posted by todd-67
Sealing shouldn't be an issue. Braking the bead, removal/ Installation can be a real bear without the correct tools.
I finished doing the back tire. I found using wax made the install part of the job easier.
Getting it off was more than a bear, it was brutal. The next time I do a rear tire I will take a die grinder with a cutting wheel and go that route.
Other than that, I like getting into it and inspecting everything. Front tire next.
Old Dec 23, 2020 | 09:20 PM
86glider's Avatar
86glider
Spray Windex on the bead .Or Like others said just bring it to an Indie shop.
Old Dec 24, 2020 | 08:36 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
As long as the rim bead is clean and smooth, and the tires bead is clean and undamaged, it should seal up just like new.
Bead sealer is a real product and does indeed serve a purpose. But with nice rims and a careful tire mounting, it really shouldn’t be needed.
Old Dec 24, 2020 | 01:23 PM
HDFORM's Avatar
HDFORM
I took my SE Ultra rear wheel to our local Honda dealer ( No harley dealer within 40miles) it cost 35 dollars, Mounted, balance, old tire disposal, 1 hour wait.
Keep it simple
Old Dec 24, 2020 | 01:32 PM
MotoJockey's Avatar
MotoJockey
Yup, I have a motorcycle tire place literally 4.5 miles from my house in town. I take the new tires bought online and the unmounted old tires/wheel and drop the off. Go home and clean and inspect while they are off, pick them up when Donnie's done with them. $25 each mounted and balanced. I take the old tires with me and turn them in for free at "Tire Amnesty Day".
Old Dec 25, 2020 | 01:41 AM
ratpick's Avatar
ratpick
The soapy water/lube is used to make it easier dismounting and mounting tires, not to seal bead. I've never heard of a "bead sealer" product--not to say it doesn't exist, but if something like that is necessary on your motorcycle, or any passenger vehicle for that matter, there's a problem with tire and/or rim because they are not designed to require any such thing and tire shops do not use it.
Many times lining up dot w/valve stem is good enough on a rear, but if there's no dot and/or you're fussy could use ride-on or dyna beads--both seem to work fine.
Most tire/motorcycle shops aren't terribly happy having people bring in stuff they purchased online to have installed (unless they don't sell tires I suppose), and will charge more to do so--off the bike I've been quoted $50-60 each vs $25-30 each if purchasing tires from them. Personally, I wouldn't bring in tires purchased elsewhere to have them installed unless I had no other choice, regardless of cost. Feels like a bit of a slap in the face to the local business, IMO.
Old Dec 25, 2020 | 01:30 PM
MotoJockey's Avatar
MotoJockey
Well you sir, must have more money than I do to throw around. If I can get my tires delivered to my front door from Dennis Kirk or Bike Bandit or wherever cheaper than buying them from my local tire guy after he steps on the price, and he's happy with still getting $25/tire for mounting and balancing them, I don't see the issue. I save money and he makes money.
Old Dec 25, 2020 | 01:35 PM
TwiZted Biker's Avatar
TwiZted Biker
Cycle Gear I use could care less as they don't usually carry much for harleys if any. Selection they do keep on hand is geared to the rice rocket crowd.
