Lubricants
Old Jan 18, 2021 | 09:42 PM
Krobinson's Avatar
Krobinson
6th Gear
Default Lubricants
Does anyone know what lubricants should be used on the following items? I couldn't find a specific listing in my service manual (2006 FLHTCUI); thanks.
- Jiffy stand
- Saddlebag and trunk latches
- Fuel door
- Brake lever
- Clutch lever
Old Jan 18, 2021 | 11:48 PM
bklynbob's Avatar
bklynbob
I use this:
Old Jan 19, 2021 | 05:31 AM
Spartanden's Avatar
Spartanden
Pretty much any good brand name lube will work on all those parts. I have some bike cable lube I bought couple hundred years ago that has a small needle type spout. I use that on all the above.
Old Jan 19, 2021 | 06:58 AM
user 47363638's Avatar
user 47363638
I use bearing grease I had laying around.
Old Jan 19, 2021 | 08:37 AM
Studlintsean's Avatar
Studlintsean
This is listed in the 2019 Service Manual and is what I use:
https://www.harley-davidson.com/us/e...ube/p/94968-09
Old Jan 19, 2021 | 09:08 AM
hattitude's Avatar
hattitude
As mentioned, any lube will work...
Lately I've been trying various dry silicone lubes for those parts mentioned.. they dry after application so there's no dripping or weeping when it gets warm like most grease products, and they don't attract dirt/dust like most petroleum products...
Bottom line is to keep them lubricated to minimize wear and improve function...
Old Jan 19, 2021 | 09:11 AM
touchdown's Avatar
touchdown
oil !!!!!!!!!!!!!!!!!!!!
Old Jan 19, 2021 | 09:14 AM
twincam10353's Avatar
twincam10353
The service manual calls for grease on the clutch & brake lever bushings. Although, this would require removing the snap-ring and bushing itself to grease it. I usually just end up spraying some lubricant on top of the pivot point and letting it seep in while I squeeze the lever in and out a few times. I pretty much use Amsoil metal protector on all my metal-to-metal contact points (floorboards, passenger pegs, fuel door, kickstand, saddlebag latches and locks, etc.) I also spray this stuff onto all exposed bolt heads as a corrosion inhibitor. It's extremely clingy and doesn't run much at all.
Old Jan 20, 2021 | 06:26 AM
skydude426's Avatar
skydude426
I also use the Harley Lube. I’ve had good luck with it. The needle applicator is nice and a little goes a long way.
Old Jan 20, 2021 | 07:40 AM
Lowoilpressure's Avatar
Lowoilpressure
One issue with wet lubricants is they attract and hold particulates. Dry lubes such as graphite powder will lubricate but not hold particulates.
And we must remember, WD-40 is not a lubricant. Great at freeing rusty parts but nothing past that.
Tom
