Led turn signal hyper flash 2012 limited
Old Jan 31, 2021 | 07:51 AM
freakfxr's Avatar
freakfxr
http://www.biketronics.com/bt801-smart-equalizer/
Old Jan 31, 2021 | 07:35 PM
bill from tn's Avatar
bill from tn
I use this on my 2012 FLTRX. It will correct your issue.
https://www.customdynamics.com/6-pin...davidson?cat=2
Old Feb 1, 2021 | 05:13 AM
eighteight's Avatar
eighteight
You`d think that someone could develop an LED bulb with integrated resistance to make this plug & play
Old Feb 1, 2021 | 09:48 PM
GregGillette's Avatar
GregGillette
Amazon Amazon
Old Feb 1, 2021 | 11:28 PM
hattitude's Avatar
hattitude
Actually, someone did....
Harley-Davidson Motor Company did it back in 2010...
When I bought my 2012 Limited, I had it delivered with the HD LED turn signals on both the front (LED signal front #68411-10) and rear (LED signals rear #68128-10)
They came in pairs, I paid $118 per set, and they come with built-in load equalizers. They were plug and play... The MoCo probably still sells them...
$236 for four LED turn signals w/ a load equalizer built in wasn't a bad price.. and since they were installed by the dealer at delivery, they fell under the 24 month factory warranty. I had one replaced 6 months shy of the factory warranty running out...
Since then, however, I've been using Custom Dynamics LED bulbs/lights/load equalizers...
Old Feb 2, 2021 | 06:01 AM
tcatnat's Avatar
tcatnat
Nevermind, wrong info.
Old Feb 2, 2021 | 06:07 AM
tcatnat's Avatar
tcatnat
Old Feb 2, 2021 | 07:08 AM
RKZen's Avatar
RKZen
I currently have the same H-D LEDs with smoke lenses and will also be changing out to the CD LEDs as well. The H-D had their own housing, so glad I kept the old ones to replace.
Old Feb 2, 2021 | 09:07 AM
hattitude's Avatar
hattitude
Originally Posted by tcatnat
If they are Custom Dynamics call them. There is a series of steps to make this stop happening. There is no need to buy anything additional. This happened to me and their instructions fixed it in less than 5 minutes.
Below are the instructions Custom Dynamics sent me when I had this issue. I would give them a call to confirm before performing any of these steps. I did this on my '18 Road King.
This would work if the OP had a canbus bike...
The OP has a 2012 Limited which is pre-canbus....
The "learning procedure" to stop the hyper flash from LED lights only works on canbus bikes... pre-canbus bikes like the OP's bike need a load equalizer in the system to stop the hyper flash...
Old Feb 2, 2021 | 09:13 AM
tcatnat's Avatar
tcatnat
Oops, completely skipped over the year of his bike. Thanks for catching. I chalk it up to pre-coffee web surfing.
