2008 rear tire
Old Mar 14, 2021 | 07:17 PM
CoMatt's Avatar
CoMatt
Default 2008 rear tire
Hey guys, looking at info on finding the widest rear tire that’ll fit a 2008 Ultra classic. All the searches I did just found info on what would fit a stock rear wheel but I’m planning on upgrading wheels, so what’s the biggest wheel/tire I can go without modification? Thanks for the help.
Old Mar 16, 2021 | 05:54 AM
pingman68's Avatar
pingman68
I could be wrong, but I believe 150 is the widest that frame will allow....
Old Mar 16, 2021 | 07:23 AM
eighteight's Avatar
eighteight
150 will fit , tire brands vary, "some ' will require an 1/8th spacer on in board side of rear sprocket to create belt clearance
This was my experience with 150 70 18 Metzler , on `99 RK
It is close to the fender
Can`t hurt to get on the floor and make some comparative measurements as you have a later model year
Old Mar 16, 2021 | 01:59 PM
caulk04's Avatar
caulk04
Not wide (cool) enough to deal with the headaches of cramming a too-wide tire in there.
Old Mar 16, 2021 | 03:48 PM
EVOrider's Avatar
EVOrider
Up to 2001.....they came with the 130. In 2002, narrower belt and improved swing arm allowed for the 140. Stayed that way until the 2010 models came out. Only exception was the 2007-2008 Se Roadking....came with a wider fender and wider swing arm allowing a 160.
Ive seen 140’s on pre-2001
ive seen 160’s on post 2002.....tight squeeze
Old Mar 17, 2021 | 07:56 AM
twistedcherokee's Avatar
twistedcherokee
I am running a 180 65 16 on my 1999Ultra. But I have modified the swing arm & rear fender. Before that I was running the 150 80 16 with a 1" wide belt. Which you already have. You may have to center the rear tire with different shims, but it does track better when that is done in my opinion.
Toby
Harley1004
Wheels/Tires
Oct 24, 2020 09:57 PM
mp_firefighter
May 13, 2017 08:07 PM
mustangharley
Sep 6, 2014 09:33 AM
noront
Nov 9, 2008 11:24 AM
Milty
Jul 30, 2008 03:35 PM
