Dakota Digital MLX-8604
Old Mar 20, 2021 | 06:40 AM
StoneTrekker's Avatar
StoneTrekker
Take this as simply discussion and not argumentative:
There’s a good reason why dark background gauges with bright numerals are easiest to see at night. Your pupils are dilated at night and they more easily contrast the bright numerals against a dark background. Think about a single distant light against black darkness. Our eyes are literally designed to see that with greater detail. You can see the bright digits on a gas price sign from half a mile in the night, but not in bright sunlight.
Almost the opposite is true in bright daylight. Pupils constrict in bright conditions. In those conditions the eye is best set up to notice a dark object (black for example) against a light background. Think about a chunk of tire laying on white concrete ahead....you’ll likely see it much quicker versus a light colored object laying on blacktop in bright sunlight. It’s also the reason your eye doc has you read a chart consisting of black letters against a white background in his bright office.
The DD MLX-8414 gauges go into high-contrast mode in bright sunlight. The black numerals against a light background instantly pop out. On mine there is no washout or fading or glare. The high-contrast setting can be set to happen automatically, with the gauges responding to ambient lighting as sensed. It can also be set to ‘off’ in which case your desired gauge display appearance will not change in bright light.
It’s a night and day difference. 🙂
Old Mar 20, 2021 | 09:03 AM
pingman68's Avatar
pingman68
Originally Posted by Charlie Day
Totally agree with your comments in regards to not seeing the gauge face when the sun is behind you, could of spent $900 Australian dollars on something better.
well I’m in Florida and the weather has been excellent lately and I can tell you there has been zero issue reading these in direct, bright sunlight. Another plus is the elimination of that annoying fogging of the stock gauges.
Old Mar 21, 2021 | 03:01 AM
Dehammer's Avatar
Dehammer
I am in Arizona and I can still read my Dakota Digital in summer high noon.
They are the best guage I've used to relay information. They look good as well. A couple or so years and no problem.
Old Mar 21, 2021 | 04:30 AM
Dano523's Avatar
Dano523
Agree and it really comes to if someone likes digital numbers or needle pointer preferences isntead.
Really, look at the watch on someone wrist, and will tell you right away if they are digital numbers read out preference, or a hand sweep needle person instead.
With needle pointer gauges, just easy for me to take a quick scan of the needle angle positions to make sure everything in in the clear on the direction they are pointing (without out having to look at the back ground numbers), then not having a back ground reference points and have to do the math in your head with just the number read outs alone. Hence oil pressure or voltage, as long as they are in the correct needle angle range, don't need to be bogged down with the specifics of what they are isntead.
Hence its a a Harley out for a daily ride, and not like a VFR finial approach into Oshkosh without ILS during EAA, that all the specifics come in handy isntead.
Old Mar 21, 2021 | 07:11 AM
StoneTrekker
What I had:
I can honestly say I’m more traditional in mindset, and I actually like the aesthetics of analog gauges. I would’ve happily never replaced mine except for the (imo) rather average job H-D did with the stock gauges on my ‘17 and ‘20 bikes. The needles....no problem picking these up....were about the only useful things for me. The gray-scale readouts telling me things like odometer/trip meter miles, gear selection, fuel miles to empty, tire pressures, and so on....those were basically hard for me to see in bright sunlight, or with reflection on the gauge face. The contrast was lacking and well....I was pretty much disappointed with having to struggle to see the more detailed information I wanted. I’m admittedly pickier than heck about the things I depend on and/or replace on my ride. Dropping about $800 into gauges....I did some pretty obsessive research on what I was getting and what I could count on. The result for me is instantly more readability at a glance, and better acquisition of the secondary info that Harley provides the rider. What I have now:
Obviously they aren’t for everyone, but I think it’s good for prospective buyers to know what they can expect from these. One other thing to be aware of: Dakota Digital gauges have an anti-reflective face which closely matches the aesthetic of the BOOM GTS screen. It’s more of a matte look instead of the glassier look which causes reflection.
Old Mar 21, 2021 | 07:49 AM
boasty's Avatar
boasty
Wouldn’t the install of these Mark your bike as true mileage unknown because it’s not the stock odometer reading
Old Mar 21, 2021 | 08:08 AM
StoneTrekker
Good question.
I’m not sure of the procedure, but there’s a way to have the odometer reading certified. Same sort of thing as if you’d replace a stock gauge for a malfunction or other reason. In my case, I didn’t do anything because I installed them with about 50 miles on the odometer. I documented that and let it go.
Old Mar 21, 2021 | 10:11 AM
maxxym's Avatar
maxxym
I don’t think so. The mileage is taken from ECU. So, it doesn’t matter which Speedo with odometer you plug in, it will grab the information from the computer anyways.
Old Mar 21, 2021 | 01:54 PM
boasty's Avatar
boasty
newer bikes yes I can see that. But like on the ops bike his odometer reading is stored in odometer you can swap odometer and it would read from it. 14+ bikes yes it’s stored and sent from Ecu.
Old Mar 21, 2021 | 04:34 PM
maxxym's Avatar
maxxym
Ahhhh ok. I did not know that. Learn something new everyday
