05 electra glide complete front end removal
Old Mar 18, 2021 | 06:50 PM
Ftwkm's Avatar
Ftwkm
Default 05 electra glide complete front end removal
Looking for words of wisdom in removing the complete front end off of an 05’ electra glide standard. I need to strip the bike to the bare frame bc it’s been ridden in 15 NY winters. The frame need to be sand blasted and powder coated due to rust. I will be blacking out the motor and tranny while I’m at it.
Old Mar 18, 2021 | 06:53 PM
MURPHCC1's Avatar
MURPHCC1
Factory Service Manual, good luck!
Old Mar 18, 2021 | 07:12 PM
svarnster's Avatar
svarnster
it is not hard take pictures so you will remember where things go. I put bolts in bags and labeled where they came from, I even labeled my wiring, but didn't really need to. service manual is a big help, so is you tube. Having a clean safe place to store parts is a plus.
Old Mar 18, 2021 | 07:18 PM
Ftwkm's Avatar
Ftwkm
Got the manual. Just hoping i can pull outer fairing, wheel fender, bars, brakes, and top triple tree. Then pull most of the unit off as a whole.
Old Mar 18, 2021 | 08:19 PM
predatornut's Avatar
predatornut
I took my ‘04 apart a couple years ago for paint. The one hiccup I had was that I got the connectors for the right and left handlebar controls mixed up. It didn’t hurt anything but I was scared when I tried to start it and nothing happened. LABEL EVERYTHING! Put every nut and bolt in bags. Since you are going that deep you might want to change out your neck bearings depending on miles and what they look like.
Good luck!
Old Mar 19, 2021 | 07:29 AM
Architect's Avatar
Architect
It is just time and patience, nothing to it. As stated, FSM and stay organized. The manual is going to likely have you jumping all over the book removing each different assembly, but at the end of the day it is just nuts and bolts. But a lot of them, organization will save you a bunch of time on the other end. No worries, a day job no more. Good luck.
FL-kruzen
Touring Parts
Jun 23, 2020 08:06 PM
mech8251
Shovelhead
Apr 21, 2011 05:34 AM
Jake707SBFMC
Dec 31, 2010 09:46 AM
JU!CEB0X
General Topics/Tech Tips
Jul 29, 2010 07:56 PM
SCHOONER
Feb 6, 2009 08:57 AM
