No spark.
Old Mar 31, 2021 | 07:20 PM
Rob Courtier's Avatar
Rob Courtier
Default No spark.
I have a 2001 Electra Glide classic, fuel injection.
I dont have a spark at the plugs.
Ok, I replaced the Crankshaft position sensor, the Camshaft Position Sensor, the coil, and the battery is new and tight.
When I first started it, after 4 years on a rack in a bike shop, I bought it and did a total rebuild of it. New harnesses and bearings, brakes, everything. When I first started it, it ran beautifully, and smoothly. After about 3 weeks, the trouble started. It started hard, and sometimes not at all. I found that I'd left the ground from the frame to the transmission of . Fixed that and it started right up, but then didn't want to idle right. Then it got worse as one day I started it and it wouldn't idle, backfired, and then started to die like it was running out of gas. Plenty of gas in tank. I checked the plugs and no spark. As I said, i replaced coil and the two afore mentioned sensors. But still nothing. I'm running out of options here. I'm going to recheck all the fuses again tomorrow. But, not holding mu h hope that that's going to help.
Old Mar 31, 2021 | 07:43 PM
BackRoader's Avatar
BackRoader
New plug wires maybe?
Old Mar 31, 2021 | 07:46 PM
Rob Courtier
Default On issue
Plug wires the checked and good.
Old Mar 31, 2021 | 10:14 PM
Teknition's Avatar
Teknition
Throw some more parts at it with no diagnostics! sooner or later you got be be right.
Old Apr 1, 2021 | 06:25 AM
Rob Courtier
True, but I don't own that type of equipment.
Old Apr 1, 2021 | 06:46 AM
Keithhu's Avatar
Keithhu
There is a trouble shooting section in the electrical service manual, I suggest you invest in that rather than throwing more money away on guessing.
Old Apr 1, 2021 | 07:22 AM
Rob Courtier
Yep, been doing that. Also got some new material from a fella here, so will be working on that today. I wished they'd left these damn computers off these bikes. Better yet, I wished I had a piece of equipment that could read them.
Old Apr 1, 2021 | 09:33 AM
hattitude's Avatar
hattitude
You should probably buy an Electrical Diagnostic manual for your bike... It could/would/will save you money from replacing good parts with new parts, and would probably help you find the issue...
However, you mentioned that you installed "new harnesses"... if they were OEM HD harnesses, the manuals would help, but if they were aftermarket and/or personally rebuilt harnesses, you are kind of on your own...
Unfortunately, the 2001 Harley Electrical Diagnostic Manuals are all inclusive, of all models that year, instead of being broken down between softails, dynas, touring, etc like the subsequent years... breaking down the manuals made them smaller, and cheaper...!!
You would need the Harley-Davidson Electrical Diagnostic Manual, Volume I and Volume II, part #99495-01. It comes in two volumes, Volume I is 3/4" thick and Volume II is 1-3/4" thick.. Unfortunately, all models are covered in both volumes, so you would need the set to have complete electrical diagnostic coverage for your Electra Glide
Even used copies are expensive... but so is throwing parts at a problem..
I did a quick check on eBay.. https://www.ebay.com/sch/i.html?_fro...95-01&_sacat=0
Good luck with your repair...
PS- you need a piece of equipment to read that bike, there is a procedure to bring up trouble codes... it involves pushing the right buttons, with the right timing & sequence, then reading the flashes... You should be able to find it doing a search if this forum... it's also covered in the Electrical diagnostic manuals...
Old Apr 1, 2021 | 09:34 PM
svarnster's Avatar
svarnster
check the bank angle sensor, main relay, and possibly the wires going to the fuel injectors. those wires have been known to be an issue. Old gas or bad gas? also the lines in tank can develop pin holes and cause it not to prime . You will get it just keep at it. check air cleaner, make sure it is not filthy. Try to narrow it down between fuel and spark, then follow the system until you find the problem.
Old Apr 2, 2021 | 11:37 AM
Z's Avatar
Z
My next move would be to pull the trouble codes. I'm sure you already have, but I'd also take a good close look at the harness. Hopefully this isn't an ECM issue
