2012 Streetglide will not turn over
FWIW.....
Short version, general rule of thumb....
The 250V /30amp fuse will protect that circuit the same as a 12V /30 amp fuse... It's the amperage draw that will blow the fuse... Both will blow if the current draw exceeds 30 amps..
The voltage listed is usually the max voltage of the circuit that the fuse will protect.... you can replace a fuse of the same amperage, with a higher voltage, just not with a lower voltage, and it will protect the circuit the same...
As for the rest of your issue, not sure what happened, but I'd guess you are missing a blown fuse, probably an inline fuse... Electrical issues are hard for me when I'm trying to figure them out in person. Over the internet.... I'm not good at electrical trouble shooting.. I'd need to sit down with a schematic, and follow it through the various systems...
Hopefully someone will chime in with a possibility for you to check out...
